No Internet
Rebecca88
No Internet
I've had no Internet connection for 2 days. It says I'm connected but won't let me on any websites etc
13 REPLIES 13
Fixes: 387
Re: No Internet
@Rebecca88 Welcome to the forums. What happens when you try to reach a site?
Rebecca88
Re: No Internet
Site can't be reached
Fixes: 387
Re: No Internet
OK. That suggests you do not have an internet connection on the device you are using.We need to go through this logically - are all the cables between the master socket and Hub secure?
How technically-minded are you, s we can ask the questions so you understand them?
How long have you been a Plusnet customer, and is this a new development?
Rebecca88
Re: No Internet
A couple of years I've been a customer. I've tried restarting, unplugging and plugging back in. Leaving it for 10 mins etc. Made sure all leads are in correctly. It was just on my phone to start with but now no devices will connect.
Rebecca88
Re: No Internet
Will not connect
Fixes: 387
Re: No Internet
OK. When did this start, what router are you using, and is your landline phone quiet - if you have one?
Rebecca88
Re: No Internet
With my phone a week ago. All devices went off last night . Plusnet hub zero
Fixes: 387
Re: No Internet
OK. In that case, I suggest you raise a fault. If your phone doesn't work, initially raise a phone fault via: https://www.plus.net/help/report-a-problem/phone/
willcutforth
Fixes: 113
Re: No Internet
Hey there @Rebecca88 and welcome to the forums. I have created a ticket on https://www.plus.net/wizard/?p=view_question&id=230817338 to answer this.
Let me know if you need anything.
 Will Cutforth
Fixes: 387
Re: No Internet
@willcutforth Anything you can publicly share - I don't see this as a client confidentiality issue?
willcutforth
Fixes: 113
Re: No Internet
@jab1 this one is account specific as to why the broadband is not working that's why I popped it in the ticket.
 Will Cutforth
Fixes: 387
Re: No Internet
OK, @willcutforth  - I understand, and bet I can guess the issue. 😀
willcutforth
Fixes: 113
Re: No Internet
Haha @jab1 I bet you can as well Tongue
 Will Cutforth
