Moved, Terrible Wiring, Terrible Connection rate
Fixes: 1,491
Re: Moved, Terrible Wiring, Terrible Connection rate
You'd normally have to disconnect / reconnect to pick up a profile change.
RHines
Hrm, I'll reconnect it in a minute. Smiley
RHines
Still no change.
LaurenB
Fixes: 131
Hiya @RHines, thanks for getting back to us.
To be honest those results don't look too concerning; a 9mb difference in sync and throughput is normal for a line with retransmission.
I can see our faults team are monitoring to ensure the line stays stable and so lets see how things go Smiley
 Lauren Barry
RHines
BUT I NEEEEEEED ALL THE SPEEDS! Wink Come on FTTP!
No, it's fine. So long as it's stable, which I think it will be with the new drop line. Thanks for the help. Smiley
RealAleMadrid
Fixes: 67
@RHines  According to the checker results WBC FTTP is available so what are you waiting for ? 😀
Maybe you want to wait until Plusnet  supply it, who knows when that will be.
LaurenB
Fixes: 131
No worries, hopefully the stability remains!
 Lauren Barry
RHines
The problem is I didn't know we could get FTTP until after we switched to plusnet. It was a HUGE mess before that, at one point we had three ISP's in two different houses. Long story short Virgin bailed at the last minute and since we both work from home we decided to just move our old service from our old house to the new house. Man if I had known about FTTP being available I probably would have gone that route. Now we have to wait lol.
Fixes: 1,491
You don't have to wait, if you move to EE / BT by calling Customer Options they will waive the early termination fees.
However, a staff member did mention being able to order FTTP in the very near future - so might be worth waiting a little while longer as could be a better price than BT etc.
RHines
We both dig plus net, we've had good support and experience which is the primary reason we've stayed for so long. So we'll just wait it out I think. Smiley
Fixes: 102
@RHines
Ah, the joys of life.
Get OpenReach round to put in a new drop wire and then a short while later get them back to replace the new drop wire with a fibre cable!!!
RHines
That is literally what the engineer said lol.
RHines
Welp it's official. It's pouring rain and my connection is still rock solid. Thanks again!
adamwalker
Fixes: 223
Brilliant, that's great to say and I hope things stay that way for you!
 Adam Walker
RHines
@bmc wrote:
@RHines
It's happening on the 21st LOL. Time for FTTP baby!
