Max Premium
- Re: Max Premium
Re: Max Premium
19-08-2014 12:40 PM
Shows a much better upload on that speed test than others I have done, but its suggesting there may be RWIN or congestion problems
Re: Max Premium
19-08-2014 12:46 PM
Re: Max Premium
19-08-2014 12:51 PM
Looks like there is some exchange congestion again here though
Re: Max Premium
19-08-2014 12:53 PM
Re: Max Premium
19-08-2014 1:06 PM
Re: Max Premium
19-08-2014 1:32 PM
And that's from my other plusnet account on the same exchange but in a different building, but I know its on different equipment at the exchange as when there is a fault usually only 1 of them fall over and the other one keeps working.
Re: Max Premium
19-08-2014 1:38 PM
What OS are you using? I take it if appropriate you've got RWIN etc tweaked?
Re: Max Premium
19-08-2014 1:57 PM
Got 2 W7 machines and a vista one running on that line and both show the same issues, as is trying to view youtube or iplayer on 2 different ipads and 2 different iphones.
Re: Max Premium
19-08-2014 2:13 PM
If you've got an open ticket you could attach that bad TBB result.
Also consider setting up a TBB BQM which may also highlight the congestion. BUT if you aren't on a fixed IP address you'll have to be a bit OCD about deleting an old one and setting up a new one if your IP address changes (gateway hopping etc).
Re: Max Premium
19-08-2014 2:31 PM
BTW speedtester works, last result was slightly better than the TBB one (3.3Mbps) but as that is within the acceptable range I guess it will be fun trying to get this looked at. It took a lot of effort 18 months ago when there was a capacity issue to get it even looked into properly without it being passed back as being acceptable and BT wont accept it to look at.
Re: Max Premium
19-08-2014 4:45 PM
It's a complete pain in the butt with these intermediate results!
Re: Max Premium
19-08-2014 5:49 PM
Quote > adsl status more
--------------------------- ATU-R Info (hw: annex A, f/w: annex A) -----------
Near End Far End
LatencyPath : 2 2
LoS : 0 0
LoF : 0 0
LPR : 0 0
RFI : 0 0
Ncd : 0 0
Lcd : 0 0
FECS : 1763 26
ES : 1 2
LOSS : 0 0
UAS : 0 0
HECError : 0 3
CRC : 1 5
RsCorrection : 45172 51
INP : 0 0
InterleaveDelay : 800 825
Last thinkbroadband test was as low as 0.49Mbps but the BT one was saying 3.91 taken right after it
Re: Max Premium
19-08-2014 6:09 PM
Re: Max Premium
19-08-2014 8:02 PM
You might like to consider trying the router's MTU at 1500 instead of 1442 - 1500 is usually the optimum setting for ADSL connections and that may also explain the TBB comment about RWIN.
Re: Max Premium
19-08-2014 8:29 PM
