Max Premium
- Max Premium
Max Premium
17-08-2014 6:33 PM
Re: Max Premium
17-08-2014 6:36 PM
Re: Max Premium
17-08-2014 6:39 PM
Here are the full stats
> adsl status
--------------------------- ATU-R Info (hw: annex A, f/w: annex A) -----------
Running Mode : G.DMT State : SHOWTIME
DS Actual Rate : 8128000 bps US Actual Rate : 832000 bps
DS Attainable Rate : 9504000 bps US Attainable Rate : 1280000 bps
DS Path Mode : Interleave US Path Mode : Interleave
DS Interleave Depth : 64 US Interleave Depth : 4
NE Current Attenuation : 7 dB Cur SNR Margin : 10 dB
DS actual PSD : 13. 9 dB US actual PSD : 12. 5 dB
ADSL Firmware Version : 232201_A
-------------------------------- ATU-C Info ---------------------------------
Far Current Attenuation : 3 dB Far SNR Margin : 15 dB
CO ITU Version[0] : 00005453 CO ITU Version[1] : 00005443
DSLAM CHIPSET VENDOR : < TI >
Re: Max Premium
17-08-2014 6:45 PM
This needs a comment from staff
Re: Max Premium
17-08-2014 6:52 PM
Re: Max Premium
17-08-2014 10:49 PM
Stats:
Uptime: 1 day, 1:55:17
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 832 / 8,128
Data Transferred (Sent/Received) [MB/GB]: 128.34 / 1.17
Output Power (Up/Down) [dBm]: 12.3 / 19.9
Line Attenuation (Up/Down) [dB]: 11.5 / 20.5
SN Margin (Up/Down) [dB]: 16.0 / 6.6
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Framing (Local/Remote): 0 / -
Loss of Signal (Local/Remote): 0 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 5 / -
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 6 / 5
HEC Errors (Up/Down): - / 3
Re: Max Premium
18-08-2014 1:59 PM
Download speedachieved during the test was - 5.53 Mbps
For your connection, the acceptable range of speeds is 1.2 Mbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.83 Mbps(UP-STREAM)
IP Profile for your line is - 7.15 Mbps
Anyone from plusnet able to look and see if there is a limit being applied to the upstream?
Re: Max Premium
19-08-2014 8:53 AM
Re: Max Premium
19-08-2014 9:28 AM
Re: Max Premium
19-08-2014 10:52 AM
It would be nice to know if I have been wasting money on the premium add on....
Re: Max Premium
19-08-2014 11:01 AM
I assume you're on the newer unlimited and not the older (2009?) unlimited product.
Re: Max Premium
19-08-2014 12:13 PM
What is your MTU set at on the router? Are you running the speed test wired or wireless?
Re: Max Premium
19-08-2014 12:25 PM
Quote > wan mtu ?
Static IP/DHCP (Max MSS: 1500)
PPPoE(Max MSS: 1492)
PPTP/L2TP(Max MSS: 1460)
% wan ppp_mss <MSS size: 1000 ~ 1500>
% Now: 1442
All tests are performed wired.
I know that it is giving a slight improvement over the standard upload, but the customer options team told me there was no benefit in having it due to the uploads being capped and would be better off removing the product.
Re: Max Premium
19-08-2014 12:33 PM
Re: Max Premium
19-08-2014 12:34 PM
Could you post the results from a thinkbroadband speed test please - the graph may show something.
