Max Premium
- Max Premium
- « Previous
- Next »
Re: Max Premium
19-08-2014 10:57 PM
Well I think I have found the source of the issue - it looks like my draytek router is on its way out. Pulled out my plusnet Thomson router and it works fine, full speed showing so next is to try a full reset of the draytek or go for a new router. Although I do suspect the NTE2000 filter may be playing up as well as the first connect with the Thomson resulted in a very low sync speed.
Message 46 of 48
(171 Views)
Re: Max Premium
19-08-2014 10:59 PM
Maybe you could try doing a firmware re-flash and forced reset of your Draytek? Maybe that will bring it back to life.
Message 47 of 48
(171 Views)
Re: Max Premium
19-08-2014 11:36 PM
A firmware flash, reset of settings indeed has returned the download speed up to normal
Message 48 of 48
(171 Views)
- « Previous
- Next »
