Little peak time latency humps
- Re: Little peak time latency humps
13-08-2013 8:54 AM
Quote The current beta has reached it's monitor limit, so you will not be able to add this monitor, please bear with us as we add more capacity to this amazing new tool!
Too many PlusNet members too obsessed?!
13-08-2013 8:55 AM
I also pinged the bbc at 11pm and got a few 110ms bursts.
13-08-2013 9:25 AM
The results actually seem encouraging:
This is Bob's fibre line on PCL-AG01. (sadly a live graph, not a snapshot)
No decent hump.
This is Bob's 2nd fibre line which we used for testing and was on ptn-ag02
Big hump. This line is never used as well.
Ex-Broadband Service Manager
13-08-2013 9:31 AM
WWWombat on PCL-AG02
13-08-2013 9:34 AM
kmilburn on PCL-AG01
13-08-2013 10:07 AM
13-08-2013 10:34 PM
Ignore the red burst around 09:20, as that was me repeatedly gateway hopping to get onto 'PCL-AG02'.
The TBB plot looks much quieter than yesterdays graph on 'PCL-AG01' (see Reply #59)
The SamKnows latency graph is much better too, without the large latency peak that occurred yesterday.
I have been doing similar light internet browsing all evening, as I did yesterday.
So I don't know whether the graphs are different because -
1) I'm on a different gateway.
2) The 'fix' on 'PCL-AG02' works better than the 'fix' on 'PCL-AG01'.
3) Whether latency or congestion on my local exchange is less tonight.
4) Whether the BT backbone is differently loaded tonight.
5) Maybe the evening 'hump' is truly random, and it just happens to be one of the better nights !
My only conclusion so far is that the 'fix' on 'PCL-AG01' didn't eliminate the evening 'hump' for me.
I will stay on gateway 'PCL-AG02' and see whether I get another quiet graph tomorrow.
13-08-2013 10:41 PM
The fix applied is the same across 01 and 02 and the graphs for the guys above cover both gateways.
13-08-2013 10:45 PM
Quote from: Kelly The fix applied is the same across 01 and 02 and the graphs for the guys above cover both gateways.
That is NOT what 'dave' said
Quote from: dave We have a theory as to what's causing the problem based on some testing we've done in the labs and want to try out two possible fixes.
So next Monday we will be making some changes to PCL-AG01 and PCL-AG02 to see if we can improve this. Each one will have a different fix on it, like I say we've got 2 possible solutions so we want to try them both out.
13-08-2013 10:53 PM
13-08-2013 10:57 PM
Stay awake at the back, and try and keep up with the rest of the class !
14-08-2013 8:08 AM
Can still see spikes at 9-10pm:
Ignore the two red lines which were router resets. Meant to be switched to 3db SNR but seems it never happened.
14-08-2013 11:37 AM
14-08-2013 11:46 AM
15-08-2013 12:28 AM
