Little peak time latency humps
- Little peak time latency humps
Re: Little peak time latency humps
12-08-2013 8:31 PM
The pattern I see is that regardless of browsing, sometimes I see virtually no hump (mostly Saturday nights it seems) and then others I see the small humps as per the second of my graphs. I do more or less the same browsing most evenings.
12-08-2013 9:07 PM
12-08-2013 9:26 PM
Quote from: Amos91 At work currently but I believe from a trace route home I am on PCL-AG02.
1 205ms RS-Gateway.local [78.129.174.1]
2 0ms 87.117.211.45
3 1ms 593.core1.thn.as20860.net [62.233.127.173]
4 1ms 202.core1.hex.as20860.net [62.233.127.1]
5 1ms linx-gw2.plus.net [195.66.236.164]
6 1ms ae1.pcl-cr02.plus.net [195.166.129.3]
7 1ms vlan128.pih-gw3.plus.net [212.159.0.199]
8 2ms link-b-central10.pcl-ag02.plus.net [212.159.2.167]
9 10ms My router
Will update tomorrow morning with an updated graph. I've noticed that there has been the odd ping spike at peak times to both google.co.uk and bbc.co.uk (30ms-100ms). Pretty disappointing start to Plusnet coming from the non-traffic shaped Be*.
Always wondered if you are so far below capacity, would no traffic management actually make it go over? Funny how your testing it as the cause.
My current graph below:
Not been in to use the Internet since now. Flat so far...
12-08-2013 9:28 PM
Ex-Broadband Service Manager
12-08-2013 9:46 PM
Quote Ping statistics for 212.58.251.195:
Packets: Sent = 100, Received = 99, Lost = 1 (1% loss),
Approximate round trip times in milli-seconds:
Minimum = 10ms, Maximum = 13ms, Average = 10ms
Google over 100 packets:
Quote Ping statistics for 173.194.34.95:
Packets: Sent = 100, Received = 100, Lost = 0 (0% loss),
Minimum = 10ms, Maximum = 49ms, Average = 10ms
12-08-2013 9:51 PM
Quote Your session timed out while posting. Please try to re-submit your message.
I hope this is still of some help. The bandwidth in use is about the amount you would see from a game but much less if you was the host in mw2-3 or bo2, console or PC.
12-08-2013 9:53 PM
12-08-2013 9:56 PM
Quote Which gateway
You are currently connected to gateway pcl-ag05.
This is located in City Lifeline House.
Sorry I thought I had everything covered.
12-08-2013 10:02 PM
12-08-2013 10:05 PM
Quote from: dave Change made on PCL-AG01 and PCL-AG02. If you can help and get on to one of those gateways would be really appreciated. Even if you aren't in to do any testing, if your line is on one of them and you have a Thinkbroadband test set up that would be useful for us to see too.
12-08-2013 10:10 PM
I was told to use a pcl gateway because they have the upgraded traffic management system and would prioritize my gaming traffic correctly. Can you confirm this is true and if not witch gateway is best for gaming? Thanks.
Will change to PCL-AG01 or PCL-AG02 as soon as I can regardless.
12-08-2013 10:11 PM
12-08-2013 10:31 PM
13-08-2013 6:29 AM
so now on PCL-AG02
Hope it helps
13-08-2013 8:38 AM
I'm not convinced that the result is any better than any other day.
Quote from: dave We have a theory as to what's causing the problem based on some testing we've done in the labs and want to try out two possible fixes.
So next Monday we will be making some changes to PCL-AG01 and PCL-AG02 to see if we can improve this. Each one will have a different fix on it, like I say we've got 2 possible solutions so we want to try them both out.
After 33 gateway disconnect/connect sequences I have now swapped gateways to see whether the alternate gateway fix works any better for me.
[quote=Gateway Checker]Which gateway
You are currently connected to gateway pcl-ag02.
