How do I allow/enable Generic Routing Encapsulation (GRE) so I can use my VPN
- How do I allow/enable Generic Routing Encapsulatio...
12-09-2012 5:27 PM
I have in the past used VPN on my plusnet broadband without any issues. I have changed jobs and can not use my new VPN. The error message I receive is and Error 806 and tells me the cause may be that GRE needs to be allowed.
I have contacted the 'support' team at plusnet and they helpfully answered the above question by telling me I had to ask via the forum.
I am far from technical and really need a step by step guide on how to do this. My IT support at work keeps telling me that its something plusnet need to do but I'm getting nowhere - can anyone help?!?
Many thanks
Re: How do I allow/enable Generic Routing Encapsulation (GRE) so I can use my VPN
12-09-2012 5:35 PM
The only thing on our side that can cause this not to function, is our user selectable Broadband Firewall which must be set to off or low for a VPN to function. We can see that this is already set appropriately for you account.
Can you confirm what type of VPN client is in use please?
Is this Nortel or another type?
Can you confirm which router you are using?
Is this still the one we sent a couple of years ago?
12-09-2012 5:42 PM
We use a PPTP microsoft vpn. Yes, I still have the last router you sent to me.
12-09-2012 6:23 PM
There was a problem using PPTP VPN's with some versions of firmware.
Check out which and how to upgrade it here http://community.plus.net/library/hardware/how-to-upgradedowngrade-the-firmware-on-the-thomson-585v7...
13-09-2012 10:00 AM
13-09-2012 10:13 AM
The easy way is to click on Change My Product here http://portal.plus.net/my.html?action=myconnection
Then Click on Keep this product and the next page allows you to order a router
i suggest the wireless one which is far superior to the wired one
13-09-2012 10:16 AM
Just shopping around at the minute so want to cover all bases.
13-09-2012 10:29 AM
13-09-2012 11:33 AM
Oldjim is correct in terms of obtaining a new modem and the tie in.
I have just checked the details of the router you are currently using. You have software version 8.2.23.0 which has PPTP removed. This is be exactly why you are seeing the issues.
You can upgrade the firmware on this unit to 8.2.6.5 linked on the page notes by MisterW, which will provide the PPTP you need to get the VPN working.
