House move x2
- Re: House move x2
- « Previous
- Next »
Re: House move x2
31-05-2009 1:45 PM
That's interesting about the FEC errors, though I'm still not convinced about that v7 firmware, too many people with to many issues.
We really need to see the bits/tone bit loading, as there is definitely something not right with your line/exchange linecard.
I think RouterStats can produce that for the Netgear, but I'm not sure.
Re: House move x2
31-05-2009 1:48 PM
Thanks again
Edit: Uploaded Bits/Tone graph - Does this help in any way?
Quote I presume the ~6min. drop in the Noise Margin on the last graph was where you changed modem or filter.
Yes.
Forum Moderator and Customer
Re: House move x2
01-06-2009 1:03 PM
First do you live near to any MW radio transmitters?
Not forgetting to power down and wait several minutes when swapping things, can you try and get the bits/tone with the Thomson. DMT v7 should work with it, but I don't know if the bits/tone is available.
Re: House move x2
01-06-2009 4:34 PM
I really do apprecaite the time you and others have spent helping me.
I can see a mast about 400/500 metres away - Not sure if its AM or something else. How do I tell?
I am wondering why you're suggesting getting the bits/tone for the Thomson. Is it to rule out a problem with the NetGear or just to see if the Thomson gives similar results. Either way, I will do as requested but meay be tomorrow before I can sort it out.
Have just Dl'ed the DMT tool and will look at that a little later.
The missing tones that you meantion - what does that mean? Is it a problem that can be sorted easily?
Cheers
Re: House move x2
02-06-2009 7:29 AM
Re Transmitter - try a local search, otherwise a photo is good - probably Mobile phone if single mast.
Re: House move x2
03-06-2009 1:12 PM
It's close to the beach but high up and around 1.5km away - it looks like a mobile phone mast. Doubt if that would affect things - yes?
I'll report back soon with Thomson DMT results.
Re: House move x2
09-06-2009 5:41 PM
Firstly, DMT Tools (v7.35) does not support appear to support Firmware version 7.4.4.4.7.0
Tried again using RouterStats buit that doesn't support Bits/Tone on the Thomson. Is there something I have overlooked?
Cheers
Re: House move x2
09-06-2009 5:46 PM
Re: House move x2
09-06-2009 5:58 PM
@anotherone.
Apart from the two Thomson routers I only have the Netgear and no way of getting another router from anywhere. Any other ideas of how to get the 2nd Bits/Tone graph.
Re: House move x2
15-06-2009 12:12 PM
The Bits/Tone graph looks much the same as the previous so where do I go from here?
I've also attached the latest router stats.
EDit: Added latest RX SN Margin from RouterStats
Re: House move x2
22-06-2009 10:09 PM
Does the previous Bits/Tone graphs indicate there is a potential fault on the line? Should this be further investigated by BT or can something else be done?
Any help appreciated, please
Re: House move x2
12-07-2009 12:46 AM
Att tends to stick at 47dB with noise margin of 9 or 12dB.
I rebooted at just after midnight to see if there was any increase in sync (was around 4300 I think) but it went down to 4048 (968Up)
Have run RouterStats again and am concerned about the Downstream Noise Margin Graph. I have added a screen shot along with the current Bits/Tone.
I still feel that I should be able to get a much higher sync speed and reliable connection yet something is stopping this from happening (rmember I am on the 21CN trial).
Any further advice/help would be appreciated.
Re: House move x2
13-08-2009 6:29 PM
As the original thread was House Move x 2 I now need to invoke the x2 bit.
I think I may have shot myself in the foot a bit by moving from Premier 2 to Unlimited and relinquishing my right to a house move
Could a member of PN either here or by PM reply with details of costs involved in another house move which, most likely, will happen within the next 2/3 months. Our current house is already on the market
Thanks.
- « Previous
- Next »
