Has my line been banded?
Jaggies
On FTTC, about 800m from the cabinet. Flaky connection issue recently resolved (Engineer traced the issue to a fault at the cabinet) , but now looks like my line is banded.
Stats from my router:
  Upstream Downstream
Current Rate (kbps) 11175 39999
Max Rate (kbps) 11127 57159
SNR Margin (dB) 6.3 7.4
Line Attenuation (dB) 7.8 17.7
Errors (pkts) 5 0
The downstream sync is suspicious, compared to the max rate figure, isn't it? I also believe that the banding is indicated by the current rate showing a value ending in 999, AICBW (I frequently am...)
Thoughts welcome.
4 REPLIES 4
Fixes: 357
Re: Has my line been banded?
Yup, @Jaggies You have been banded, due to your earlier issues. Maybe asking PN to do a line reset will resolve it.
Fixes: 240
My first take here that you’ve been provisioned on 40/10 but the 11+ US somewhat refutes that.
AIUI getting a DLM reset on VDSL is not as easy as it used to be.  You could be faced with waiting for automatic adjustment over three weeks.
Jaggies
Thanks for the confirmation.
If a staff member sees this, if possible, please see if you can get my line reset, otherwise I'll let nature take it's course.
Jaggies
Actually looks as though DLM may be working.
Stats look better, anyway...
  Upstream Downstream
Current Rate (kbps) 11283 44754
Max Rate (kbps) 11295 61187
SNR Margin (dB) 6.1 6.4
Errors (pkts) 62 27
