Flashing orange router
Fixes: 383
Re: Flashing orange router
@tearlec wrote:
Beware Google will autotype you to L254 not 1.254 when you do this it leads to dodgy webpages where you might lose control of your router!
I find that very hard to believe! Exactly where is Google 'auto-typing' this?
tearlec
It's true type in and see on Google also watched video saying same thing
tearlec
Start typing in the address Google will pop up a similar address with L instead of 1.254 it leads to website Norton blocks
Fixes: 383
I am very sorry, @tearlec , but I still find it extremely hard to believe - it has never happened to me in nearly 40 years of home PC use.
Also, it would help if you actually answered questions asked.
Fixes: 383
Ignore Googles 'suggestions' and force the correct address.
tearlec
Sorry you don't believe me I can't do anymore but say what happened to me when I started typing in the hub address
tearlec
Bit tired from day out! Started typing address and Google suggested the one with an L not A1 should have been more awake
tearlec
Yes linked by short cable hive to router they recommend up to 1 m away but not possible with setup so have switched to channel 1
Fixes: 480
Stepping back from this a bit and looking afresh and unfettered by any knowledge of how these things work!
I can understand the Hive upsetting the router wireless traffic, but crashing the WAN connection when the boiler is on (assuming that this is what happens)? I find this Hive hub needs to be within 1m of the Router hard to believe. Surely if the Hive was crashing the router it would not be synchronised with the boiler starting? I would expect the Hive and Router to be constantly communicating
I would be more inclined to look at @Dan_the_Van's comment re REIN from the boiler, especially if the router and boiler are on the same mains ring. My first move would be to move the router to a different mains socket and/or run it from a filtered extension lead.
tearlec
The boiler I think is on separate mains ring as boiler is upstairs router in the kitchen.I disconnected hive hub last night and blue light on this morning so it seems like the hive is definitely interfering with Plusnet router.I have tried moving hive hub away as far as I can from router it didn't work but waiting to see if changing 2.40ghz to channel 1will help.The added complication is unfortunately open reach decided to work on the poles along our road last week so will apply a wait and see tactic
tearlec
Thought I had found a fix to this but no came down this morning to orange flashing but this time slightly touched hive hub and immediately went blue, despite moving hub and changing channels nothing works .So going back to basics and removing hive hub as I can control heating directly with thermostat and hive hub only really useful when going on holiday to check remotely and can program thermostat beforehand
RadioFox
@tearlec  When the router is flashing orange, have you listened on the landline to see if there's any interference/crackling on the line?
Edit...I thought you might still be on copper landline, but just realised that you say you are FTTP, so ignore the above.
Fixes: 580
TBH I'd missed that!. If it is FTTP then for the Orange light to be flashing, the router must be seeing the physical WAN port drop and reverting to looking for DSL sync. Or maybe its being reset but not sure if that would revert to DSL ?
As @jab1 said back here https://community.plus.net/t5/Broadband/Flashing-orange-router/m-p/2046706#M375585 the router event log would be useful
@MisterW
Not really been following this thread that well but yes post 12 states Full Fibre.
From my checking the Hub two always auto senses the WAN connection at power up, it also detects a reconnection of either the DSL or WAN port, no power cycle required.
@tearlec
When the Hub light is flashing orange what do the ONT lights show?
For a flashing orange light on the Hub the WAN cable would need to be disconnected or the ONT might be powered off.
Fixes: 383
@RadioFox  @MisterW  @Dan_the_Van
This comment I find interesting - it  suggests the Hive unit is the culprit:
