Flashing orange router
FIXED- Subscribe to RSS Feed
- Flashing orange router
Re: Flashing orange router
Tuesday
Wednesday
Wednesday - last edited Wednesday
@tearlec They replaced by master socket too
Eh! i thought you were on Full fibre ? the master socket is no longer used , there's a separate box, an ONT (Optical network terminator) to which the router connects with an ethernet cable
Wednesday
Well that makes the last few posts 'red herrings'...
We now need the event log to investigate any further
@tearlec wrote:
No just fttc no pure fibre available here yet
Oh. You said in post #12 that you were on full fibre. That's why I withdrew my question about noisy landline.
In that case, when the orange light is flashing again, have a listen on the landline to hear for any unusual noises.
You can dial 17070 & choose option 2 for the quiet line test. It should be completely quiet. No crackling or other noises.
Wednesday
Wednesday
Dan_the_Van mentioned earlier that it could be caused by REIN. There's an interesting article about it here:-
::. Kitz - REIN, SHINE & RFI .::
As it says in the article, and as MisterW says, a look at your router log would be helpful.
Thursday - last edited Thursday
Thursday
Again a request for the Hub event log, there is NO private data in this file, best performed on a PC.
Connect to the Hub two using a web browsers, from the Home page navigate
>Advanced settings -->Technical log -->Event log --->Export.
This exports the event log as a CSV file to the PC download folder, it can be attached to a post.
The event log will detail time of "DSL link down" (Hub light flashing orange), LAN and WiFi device connection activities, along with other data, NO user information.
Thursday
Thursday
@tearlec If you haven't got a PC working, what are you using?
Thursday
Thursday
