Flashing orange router
FIXED- Subscribe to RSS Feed
- Flashing orange router
Saturday - last edited Saturday
Fixed! Go to the fix.
Re: Flashing orange router
Saturday
Is your boiler a 'smart' one? A lot of these types of IoT things can have unintended effects on connections, but it does sound strange.
Can you export your Hubs Event Log and attach the resulting csv file to a post, please.
Saturday
Saturday
OK. Sight of your Hubs error log would still be useful, though.
Saturday
Saturday
flashing orange light is usually associated with a break of the upstream connection from the Hub to internet.
For copper DSL port to the master socket and to the openreach network, for Full Fibre the WAN cable to the ONT.
For a DSL connection there could be electrical interference (REIN) when the boiler is operating which is disrupting the dsl signal, stopping the boiler might explain the blue light returning.
Saturday
@tearlec wrote:
apparently it's a common thing that hives software has a tendency to interfere with Plusnet router
Would be interesting to know the source of this - we haven't, to the best of my knowledge, seen many examples of this on the forum.
Saturday
Hive uses Zigbee wireless protocol, which is different to a routers WiFi.
But, they share the same 2.4Ghz radio frequency spectrum, so co channel interference can occur.
It is important not to have the Hive hub and router close to each other. You could try moving the Hub Two Wifi channel from Smart, try using channels 1, 6 or 11 in turn to see if that helps.
Saturday
Saturday
Looks like similar issue
Sunday
My Hive Hub has to be connected to the BT Homehub(not PN) using a cable. If that's the case here, then the Hive Hub can't be sited far away from it.
Maybe I'm lucky because there have been no issues with the wireless connection between the Hive Hub to the receiver and room stat.
Am I wrong in thinking the orange flashing light indicates the router is trying to connect to the internet or connecting via WPS?
Sunday
Nothing to do with WPS, there is a light behind the WPS button which flashes Blue when the button is pressed.
Flashing orange is the Hub not having a connection to the internet, as I previously described, a constant flashing would be no internet connection to either the DSL or WAN port.
Solid orange would indicate an issue with the connection.
Monday
