Fibre broadband drop out
Bridiebabes
Re: Fibre broadband drop out
Fixes: 382
Sorry - to be honest, I am not surprised - that downstream SNR is much too low for your line length. Keep your eyes on it over the weekend, and post back if you get more.
RealAleMadrid
Fixes: 68
@jab1  It's nothing to do with the SNR value, I think the engineer was one of the type that changes the master socket and blames it for the fault and does not check anything else. Although it was a very odd looking front plate on the old master socket.
@Bridiebabes You still have a line fault, you have had a significant change in the line attenuation which should never happen, so your speed has dropped by over 50%. There must be a bad joint somewhere on the line.
You need to get back to Plusnet and tell them the fault has not been fixed.☹️
Fixes: 382
@RealAleMadrid Thanks for picking up on the attenuation - I admit to not spotting it. However, I still think, given the figures in those screenshots, such a low SNR is not going t help, although I totally agree @Bridiebabes needs to get back onto PN and ask them to get the line properly checked - there is obviously still a major fault somewhere, and given it is a SOGEA connection, that will be somewhere in the OR infrastructure.
James30
Fixes: 32
@Bridiebabes Hiya, I tried to ring to book in a visit as the test is still failing from our end. Can you either let us know your availability Monday-Friday 8-1 or 1-6 or call us on 08004320200.
I assume you have the router in the master socket with no other telephony gear connected through extensions, bar a filter if you have a non prefiltered socket?
James - Plusnet Sheffield
Fixes: 382
@James30 - thought your phone number was now 0330 123 9123?
Bridiebabes
Hi James
Yes sorry did see the phone call, I was in a meeting.
The socket was changed by the engineer Saturday to a MK4 socket so the filter he said is built into the socket.
I'm free anytime as I'm off for the summer holiday
Thank you
SammyM
Fixes: 101
Hiya @Bridiebabes
Testing is actually come back clear today, how has your connection been?
 Sammy M - Sheffield Team
Bridiebabes
Been a lot better, openereach attended today and fitted a new cable
Thank you
SammyM
Fixes: 101
Ah brill, keep an eye on it and drop us a line if the issue comes back again.
