Fibre broadband drop out
- Fibre broadband drop out
Re: Fibre broadband drop out
29-07-2024 7:27 PM - edited 29-07-2024 7:27 PM
@Bridiebabes you said above 'it is an old-style master socket' If it is is an NTE 5C, it will be clearly marked as such - and have separate phone and broadband sockets.
EDIT to add - that is not a 5C.
29-07-2024 7:38 PM
@Bridiebabes if you don't use a phone,then for a start unplug that telephone cable.
I'd then unscrew the 3rd party faceplate and plug the filter directly into the test socket on the Openreach box.
29-07-2024 7:57 PM
29-07-2024 8:11 PM
Yes, it might not look neat but it may be better performing
01-08-2024 4:04 PM
Regards
01-08-2024 6:13 PM
@Bridiebabes If you have not heard anything I would assume that no engineer appointment has been booked.
How did you reply to the text from @MatthewWheeler in msg#16, not sure if a text reply is monitored?
A private message or a response to a ticket ( if there is one) in your member centre account would be better.
02-08-2024 9:03 AM
Sorry to hear you've not had a confirmation @Bridiebabes
I've sent a e-mail and text confirming the appointment
Let us know how you get on
02-08-2024 9:06 AM
Will keep you informed how it goes
Thank you
03-08-2024 12:16 PM
Thank you
03-08-2024 12:30 PM
@Bridiebabes To be honest, I admit I was a little wary of your 'box'. Hope the replacement works and solves the issue.
Just for my information, can you post those two screenshots from your Hub again please - as they are currently?
03-08-2024 12:37 PM
03-08-2024 12:38 PM
03-08-2024 12:40 PM
03-08-2024 12:43 PM
@Bridiebabes Thanks for those two screenshots - your figures look much better now. The downstream SNR figure looks (to me) a little low, but unless you notice any connection drops, ignore my concerns.
03-08-2024 2:55 PM
