Unable to access some services despite Plusnet appearing to work
seadog
I have been getting problems with the broadband over the last week. These include inability to access the red button on BBC channels, the LG TV losing connection, very slow connections on some services from my desktop and some sites timing out such as supermarket booking slots.
Some things work fine, such as email and most websites.
This is despite appearing to have a fast line according to speed checkers. I've restarted the hub a number of times and checked connections. There is nothing obvious when I look at the plusnet two hub manager.
Any suggestions are very welcome!
22 REPLIES 22
Fixes: 102
Re: Unable to access some services despite Plusnet appearing to work
@seadog
Have a look at Help & Support and go Fault Finding.
Start with the phone and if that comes up clear try internet faults.
Fixes: 353
Don't know about the TV issues, but the sites timing out/taking a long time to load sounds site specific, rather than a general problem.
@seadog  Can you be a bit more specific with regards to the problem sites?
seadog
Hi John,
Yes, here are some examples:
booking slots on Ocado takes about 2 minutes just to get the days up
booking slots at the gym often times out
red button on BBC and Eurosport don't work "sorry this service is unavailable"
BT performance checker does not fully load
Amazon Kindle is not downloading an order
All these sites used to work seamlessly. It feels as though there is a problem with sites requiring data to be uploaded in a certain time frame and the system locking up (I might be wrong here). I do use a TP-Link router to enable connection via LAN cable to some devices. However, my PC is connected directly to the router and that has problems as well.
The problem did seem to start after a brief power cut. I don't know if this could have caused a problem.
Fixes: 353
@seadog As other sites seem to load OK, this is a weird one, so, one step at a time. If the BT checker won't load, can you try : https://www.speedtest.net/ and post a screenshot of the result.
I don't know what the reporting capabilities of your TP-Link are like, but is it possible to find any of the data shown in the picture below;
seadog
Thanks, John.
The BT speed checker works intermittently. When it does work I get this:
Basic Speed Test
Broadband Speed Test
Executed Successfully
PING
22
ms
DOWNLOAD
57.11
Mbps
UPLOAD
0
Mbps
If you are testing 500Mb/1000Mb product speeds please .
The upload appears to run fine at 18 Mbps. It briefly displays 18.2 Mbps before resetting to zero.
I use the plusnet 2 hub as my router. The TP-link is just a 5 port gigabit ethernet network switch.
The speedtest gives this:
Result ID
 Download Mbps
56.10
 Upload Mbps
18.68
Ping ms  9  75  72
Connections
Multi
PlusNet
The plusnet hub technical log gives this:
This is a list of your Plusnet Hub settings and current statistics.
Product code:Plusnet Hub Two
Serial number:+108417+2230001897
Firmware version:v0.10.00.04201-PN
Firmware updated:28-Jun-2023
Board version:R01
GUI version:1.9 16_08_2022
DSL uptime:0 Days 0 Hrs 26 Mins
Data rate:19.999 Mbps / 60 Mbps
Maximum data rate:21.394 Mbps / 79.546 Mbps
Noise margin:7.0 / 11.1
Line attenuation:9.8 / 15.9
Signal attenuation:9.8 / 17.2
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:55.6 MB Uploaded / 225.0 MB Downloaded
Broadband username:[Removed]@plusdsl.net
2.4 GHz wireless network name:[Removed]
2.4 GHz wireless channel:Smart (Channel 11)
5 GHz wireless network name:[Removed]
5 GHz wireless channel:Smart (Channel 36)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:On
MAC address:A8:A2:37:B8:D1:39
Software variant:-
Boot loader:0.1.7-PN (Thu Nov 30 09:45:22 2017
The event log is:
admin login success from 192.168.1.188
19:16:07, 04 Aug.
ARP [add] br0(eth0) 192.168.1.96 9c:c9:ed:e9:25:6a
19:16:07, 04 Aug.
ARP [del] br0 192.168.1.96 9c:c9:ed:e9:25:6a
19:16:05, 04 Aug.
admin timeout from 192.168.1.188
19:13:18, 04 Aug.
19:13:18, 04 Aug.
19:12:17, 04 Aug.
DHCP device Disconnected: 192.168.1.221, 4e:cd:92:f9:7c:bd, Chris-s-S22
19:12:17, 04 Aug.
LAN [DEL] ARP 192.168.1.221 with 4e:cd:92:f9:7c:bd from br0
19:12:14, 04 Aug.
ARP [del] br0 192.168.1.221 4e:cd:92:f9:7c:bd
19:09:21, 04 Aug.
19:09:21, 04 Aug.
19:07:40, 04 Aug.
19:07:40, 04 Aug.
19:05:01, 04 Aug.
ARP [add] br0(eth0) 192.168.1.221 4e:cd:92:f9:7c:bd
19:04:59, 04 Aug.
19:04:34, 04 Aug.
DHCP device Disconnected: 192.168.1.248, 14:91:38:25:64:8b, unknown
19:04:34, 04 Aug.
LAN [DEL] ARP 192.168.1.248 with 14:91:38:25:64:8b from br0
19:04:32, 04 Aug.
ARP [del] br0 192.168.1.248 14:91:38:25:64:8b
19:02:46, 04 Aug.
LAN [DEL] ARP 192.168.1.86 with 20:17:42:f2:59:0a from br0
19:02:44, 04 Aug.
ARP [del] br0 192.168.1.86 20:17:42:f2:59:0a
19:01:40, 04 Aug.
ARP [add] br0(eth0) 192.168.1.248 14:91:38:25:64:8b
19:01:36, 04 Aug.
DHCP device Connected: 192.168.1.248, 14:91:38:25:64:8b, unknown
19:01:36, 04 Aug.
DHCP lease issued 192.168.1.248 to 14:91:38:25:64:8b , lease duration is 86400 seconds
19:01:36, 04 Aug.
LAN [ADD] ARP 192.168.1.248 with 14:91:38:25:64:8b from br0(eth0)
Many thanks for your help!
Mark
Moderator's note by Mike (Mav): Personal information removed from a public forum (to an area that staff can see).
Fixes: 353
Assuming you haven't turned the HUb2 on and off before gathering that data, you have an issue. It is showing a DSL uptime of only 26 minutes, and what I would call an elevated downstream SNR value.
If you still have a normal landline connection, can you run the Quiet Line Test, please - dial 17070, select option 2. After the confirmation of you number, there should be NO noise whatsoever, save the regular 'Quit Line Test' message.
seadog
Hi John, Thanks.
I had reset the hub shortly before as I had started going through the tests suggested by bmc (Hero). I'll try a hard reset in a bit.
The quiet line test was very quiet, I couldn't here a thing until the message blasted out!
Mark
Fixes: 353
OK, @seadog . Personally, I  doubt any resetting will achieve anything, and probably cause more issues than it will solve. I suspect your previous rests have already 'upset the Dynamic Line Management kit in the FTTC cab, and doing more will just aggravate the situation.
To be honest, I'm a little unsure of what to suggest next - your initial post suggested a possible ping or routing issue, but your ping is good, so that is one none-issue.
Do you know how to perform a traceroute?
seadog
Thanks. Here's the traceroute:
Tracing route to pingbox1.thinkbroadband.com [80.249.99.164]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms *.*.*.*
2 5 ms 4 ms 4 ms 172.16.19.219
3 * * * Request timed out.
4 7 ms 7 ms 7 ms 128.hiper04.sheff.dial.plus.net.uk [195.166.143.128]
5 14 ms 19 ms 15 ms peer7-et-3-0-1.telehouse.ukcore.bt.net [109.159.252.152]
6 8 ms 8 ms 7 ms linx-gw1.thn.ncuk.net [195.66.224.240]
7 8 ms 8 ms 7 ms ae11-11.edge-rt2.thdo.ncuk.net [80.249.97.21]
8 8 ms 7 ms 7 ms te1-51-36.core-rs3.thdo.ncuk.net [80.249.97.72]
9 8 ms 8 ms 7 ms po5-32.core-rs4.thdo.ncuk.net [80.249.97.90]
10 7 ms 7 ms 7 ms pingbox1.thinkbroadband.com [80.249.99.164]
Trace complete.
The 3rd one looks a bit dodgy but I don't know how to interpret that.
Fixes: 353
That is a good ping - the third hop probably doesn't respond t ping  requests, and is perfectly normal. What about one to ocado.com?
Marksfish
Seasoned Pro
Fixes: 4
When you've reset your router, did you notice if the IP address changed? It could be an ip issue? I say that as an LG owner and I have been using mine all day with the apps and BBC with no issues. I no that doesn't help you though.
Also, not sure if editing out your PN username may be a good idea.
Mark
seadog
The one to Ocado looks fine. Most of the time, Ocado is fine. It's just when I need to book a slot that it goes really slow or times out. Speedtest.net also seems ok. It's a complete mystery.
C:\Users\mark>tracert ocado.com
Tracing route to ocado.com [107.162.180.20]
1 <1 ms <1 ms <1 ms
4 7 ms 7 ms 7 ms 132.hiper04.sheff.dial.plus.net.uk [195.166.143.132]
5 8 ms 7 ms 7 ms core6-hu0-0-0-15.faraday.ukcore.bt.net [195.99.127.66]
6 7 ms 8 ms 7 ms 166-49-209-194.gia.bt.net [166.49.209.194]
7 9 ms 10 ms 10 ms cc-uk-thn-01-linx-01.controlcircle.com [195.66.225.161]
8 * * * Request timed out.
9 9 ms 9 ms 9 ms 107.162.79.5
10 9 ms 9 ms 9 ms 107.162.180.20
Trace complete.
C:\Users\mark>tracert speedtest.net
Tracing route to speedtest.net [151.101.194.219]
1 <1 ms <1 ms <1 ms
2 5 ms 4 ms 5 ms 172.16.19.219
5 7 ms 7 ms 7 ms peer2-et-7-0-1.slough.ukcore.bt.net [109.159.252.120]
6 * * * Request timed out.
7 7 ms 7 ms 7 ms 151.101.194.219
Trace complete.
C:\Users\mark>
Fixes: 353
If it is when trying to book a slot, that suggests to me that it s something in the Ocado internal network which is the issue - and best of  luck trying to ask them about that - the call centre staff won't have clue what you are on about.
seadog
Thanks. The IP address doesn't seem to change. As I have reset the router a number of times, is it best to just leave it now to settle down (hopefully)?
