Exchange Status Checker
jelv
Fixes: 10
Re: Exchange Status Checker
Another two weeks passed and still no update! Sad
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
mitchell20
I don't see the point of having an exchange checker if no-one can be bothered to actually update it.  It's now almost 2 months out of date.  I just hope PN staff don't actually use it during a fault finding process?
MrC
Wouldn't it be better for this tool (or something functionally similar) to be available direct from BTW? After all they are responsible for maintaining the base data. Maybe the ISPs & OFCOM should get together and put pressure on BTW to produce something?
tonycollinet
Where do you find out when it was updated. The only date I can find for my exchange is "last updated 3 March 2009" which if this is the last update puts it 6 months out of date.
Peter_Vaughan
The date it was last updated is not shown anywhere.
The date you see is the last date the status for that exchange changed. The CSV import file does not contain an update for event exchange very time. Sometimes exchanges are only included when something changes. As usual BT (Not BTW) are inconsistent with their supplied information
James
Re:Exchange Status Checker
This isn't something that we've forgotten.  We're trying to find a way of automating things and once we do, it'll be updated regularly.
Bob is still on the case.
jelv
Fixes: 10
If someone raises a speed fault and it appears that the IP Profile etc is all fine so it could be down to congestion, is the exchange status one of the things the agents check for? If so where do they get the information from?
Anotherone
Champion
Fixes: 21
Quote from: tonycollinet
You need to go to the VP status page to see when the record was last updated. Currently it seems as though it was 18th September. Oh dear  Roll_eyes
Maybe Bob could give us an update on the situation.
jelv
Fixes: 10
Bet the answer is that they are looking to improve or automate the process.
It obviously hasn't occurred to them that they could continue running the process the same manual way as it has always been done until the improved process is available. Sad
James
We're trying to get it automated.
Simple fact is that Phil is too busy with BSC work to find the time to get it done, and it takes a fair time to do it manually since BT made some changes a while back.
jelv
Fixes: 10
Then suspend it until the automatic updating is in place!
Quote from: jelv
I don't want to see it removed, but out of date/misleading information is worse than no information.
jelv
Fixes: 10
Quote from: jelv
Any chance of an answer to this question?
James
Believe it checks with BT, rather than our own exchange checker.  It's an automated check on the faults wizard.
jelv
Fixes: 10
So while the status checker is out of date, if anyone suspects their exchange they should raise a ticket asking for about the status!
csogilvie
If someone gathers the data together from BT, I'm sure I could probably actually upload it....
