Disconnections and really slow speeds
LeeSmall
I have experienced frequent disconnections (12+ per day) over the past week. The duration of these disconnections are now getting much longer and the speed I do get when I am connected is really bad (96kbs upstream and 200kbs downstream).
I reported a fault on Tuesday but nothing seems to be happening - I have had no feed back and the only update I get when I call in is somebody will call me back.
I have tried 2 different routers (Netgear DG834N and a D-Link), switch cables, etc.  I don't have any microfilters as I have an ADSL V1.0 master socket fitted by BT.
Can somebody please help me or at least give me some idea when the problem is going to be fixed?  I work at home most of the time and without an internet connection I am really stuck.
Lee
LeeSmall
Re: Disconnections and really slow speeds
Just been told that I need to wait 72 hours for a response from PlusNet.  Then possibly an additional week to get a BTOR guy out.... that means nearly 2 weeks without broadband.
Not a happy customer....  I just can't understand why it takes Plusnet 72 hours to perform checks before handing it over to BTOR...
I have tried 2 routers, wired and wireless, 2 ADSL RJ11 cables, etc so I am pretty sure it's not a fault at my end.
LeeSmall
I have just flashed my Netgear DG834N router with a custom firmware where I can reduced my SNR percentage. If I lower it to around 20% I can just about get a VERY slow connection.
If I leave it at the default I can't get a connection at all.
LeeSmall
Just rebooted the router and I now have a better connection speed Smiley  but the speedtest results are really poor:
Download speedachieved during the test was - 47 Kbps
For your connection, the acceptable range of speedsis 50-250 Kbps.
Additional Information:
Your DSL Connection Rate :672 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 135 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 12.77:21.28:65.96 (SBE:NBETongueBE)
Fixes: 10
You now need to leave everything alone and keep your router constantly connected - BT will then raise your IP Profile and once the Plusnet stable rate follows that you will see the higher speeds. Officially it could take a few days but for the change you've seen it might be quicker.
Edit: See http://www.kitz.co.uk/adsl/IPprofile.htm#IPprofile_increase_time
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Hi Lee,
I've raised this for you, there's some pretty bad intermittent connectivity going on there. Should be an update on your ticket shortly.
LeeSmall
I have only been with plusnet for nearly 2 months and I have only had about 3 weeks without any issues  Cry
I still don't have anything thats usable.... In fact I have had dialup speeds better than I am getting  Angry
Speedtest results:
Download speedachieved during the test was - 52 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 19.23:28.85:51.92 (SBE:NBETongueBE)
I keep on being told to wait 24, 48 or 72 hours for updates & nothing seems to be happening......
LeeSmall
BT came to my house today  - nothing wrong with the line but he couldn't get a decent connection either.  He tried to get hold of PlusNet for over 10 minutes but nobody would answer the phone  Angry Angry Angry Angry
Looks like it's a PlusNet issue so I am now back to square one.....
Fixes: 10
Pah!
If your IP Profile is still at 135 that is NOT a Plusnet issue.
LeeSmall
Just repeating what the BTOR guy told me.  I have already had more than 2 disconnections today -  I am totally fed up with PlusNet.
Fixes: 10
All Plusnet will be able to do is push the fault back to BT. It's unfortunate that you got an engineer that's about as much use as a chocolate fire-guard.  Sad
LeeSmall
Well I have just requested a MAC code - support have just told me that as the fault is intermittent (over 6 times a day) then I could be in this position for a while.
Fixes: 10
Presumably you are going to a LLU ISP (otherwise you'll still be in the same situation).
LeeSmall
I wouldn't need a MAC code to go to a LLU provider  Wink
No - just another provider who doesn't spend nearly a week running their own tests before getting BTOR involved and then not answer the phone when BTOR call them
I have also just been told that BT didn't run the correct tests when they were here and that they a probably going to need to come back to my house again so thats another morning I have to wait around for them to turn up.
ajcraig
Exactly the same symtoms here.....
I have reported my problems on numerous occasions and they are all dismissed.
Even after requesting management to step in they still fail to do so.
I have requested a MAC Code so I can move to another provider as the connection cannot be trusted and the customer support team are hopeless.
