DLM Reset / Line Cap
FIXED- Subscribe to RSS Feed
- DLM Reset / Line Cap
- « Previous
- 1
- 2
- Next »
Re: DLM Reset / Line Cap
23-05-2022 1:49 PM - edited 23-05-2022 1:50 PM
Genuinely is a weird issue, but the line's not banded and well within speed estimates, so not sure what more we can do.
I'll attach below a full copy of the testing which I can see. To start with, a GEA Service Test:
| GEA Test Detail | |||
| Circuit ID | NA | Service ID | [redacted BBEU] |
| Test Outcome | Pass | ||||
| Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
| Description | GEA service test completed and no fault found . | ||||
| Main Fault Location | OK | ||||
| Sync Status | In Sync | ||||
| Downstream Speed | 76.3 Mbps | ||||
| Upstream Speed | 20.0 Mbps | ||||
| Appointment Required | N | ||||
| Fault Report Advised | N | ||||
| NTE Power Status | PowerOn | ||||
| Voice Line Test Result | Not Run - Unable to run | ||||
| Bridge Tap | Not Detected | ||||
| Radio Frequency Ingress | Not Detected | ||||
| Repetitive Electrical Impulse Noise | Not Detected | ||||
| Cross Talk | Not Detected | ||||
| Estimated Line Length In Metres | -47.8 | ||||
| Upstream Rate Assessment | Very Good | ||||
| Downstream Rate Assessment | Very Good | ||||
| Interference Pattern | Not Detected | ||||
| Service Impact | No Impact Observed | ||||
| Home Wiring Problem | Not Detected | ||||
| Downstream Policing Discard Rate | 0.0 | ||||
| Customer Traffic Level | Upstream and Downstream traffic detected | ||||
| Technology | VDSL | ||||
| Current 15Min Bin Retrains | 0 | ||||
| Last 15Min Bin Retrains | 0 | ||||
| DP Type | External | ||||
| Profile Name | 0.128M-80M Downstream 5dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off | ||||
| Time Stamp | 2022-05-10T13:45:00 | ||||
| Parameters | MIN | MAX | AVG |
| Down Stream Line Rate | 79.9 Mbps | 79.9 Mbps | 79.9 Mbps |
| Up Stream Line Rate | 19.9 Mbps | 19.9 Mbps | 19.9 Mbps |
| Up Time | 900.0 Sec | 900.0 Sec | 900.0 Sec |
| Retrains | 0.0 | 0.0 | 0.0 |
| Current and Last 15 Minute Bin Performance | ||
| Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
| Start Time Stamp | 2022-05-23T12:16:15Z | 2022-05-23T12:31:15Z |
| Ingress Code Violation | 1 | 2 |
| Egress Code Violation | 0 | 0 |
| Errored Seconds | 0 | 0 |
| Severely Errored Seconds | 0 | 0 |
| Unavailable Seconds | 0 | 0 |
The downstream speed here is showing 76.3mbps as this can take into account the lower than normal IP profile, if retransmission is enabled, in this case in a high state.
For good measure, I've also run a line test separately as "Voice Line Test" didn't run as part of the GEA. Line tests passed.
Looking at what we call RRT data is showing the raw sync rate at 79998.
I wonder if the Hub calculating the data rate in the same way which a GEA does? Seeing as it's exactly the same figure.
23-05-2022 2:01 PM
Yep, very weird.
I do have a billion router somewhere if I can find it to see what that syncs at as the hub's modem is really that is only thing left?
The openreach engineer did say he was getting 80 on his test equipment when the fault was fixed a few months back.
23-05-2022 2:12 PM
Yeah maybe. I'd bet that this is all caused by retransmission, which should hopefully be automatically removed soon as your line looks to be in excellent shape. Definitely worth giving your Billion modem a go if you can find it. ![]()
23-05-2022 8:44 PM - edited 23-05-2022 8:44 PM
@Icipher My fave router is Billion. Very good router cos it got broadcom chipset as I do know the FTTC cabinet from Huawei 288 will love that Billion router!
Good luck if you find your billion router and worth a try out. Remember to powered down for 30 minutes to avoid DLM.
24-05-2022 8:16 AM - edited 24-05-2022 8:17 AM
Good news @Gandalf DLM resynced the line during the night - getting very close to where it was before.
Going to leave it alone as far as the Billion is concerned for another week, as I have a feeling it may sync again in another few days at 79,999
Thanks again everyone for the help and input, will mark it as resolved 👍
24-05-2022 8:26 AM - edited 24-05-2022 8:26 AM
Cheers for the update,
I'm glad to see the Hub's data rate is improving! A GEA test is now showing a full 79.9mbps sync. It'd be interesting to see if retransmission was lowered or removed completely overnight, but the profile won't update our side until tomorrow.
Snippet from the GEA Service Test:
| Downstream Speed | 79.9 Mbps |
- « Previous
- 1
- 2
- Next »
