Plusnet are DEFINITELY throttling you
- Plusnet are DEFINITELY throttling you
21-05-2022 9:55 PM
5 years with Plusnet, never saw more than 28mbps down / 6.5mbps up. BT cabinet checker saying line should be capable of 34mbps down / 7.5mbps up.
Switched to Vodafone 3 months ago. Same router, same PC, same mobile devices....same everything. Never seen less than 34mbps down / 7.5mbps up.
I don't know what they are doing but they are DEFINITELY not providing customers with the full speed available from Openreach.
Re: Plusnet are DEFINITELY throttling you
21-05-2022 10:55 PM
Or alternatively it could be that Openreach reset the DLM for your line when you changed ISP.
22-05-2022 12:19 AM
If it is Plusnet policy why are they not throttling me?
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
23-05-2022 9:02 PM
I was getting 25mbps down for three years until the end of 2020 when they reset the DLM as part of the fault diagnostics/repair process. That's when it went up to 28mbps.
They told me they'd done 'everything possible' to increase speed and what I was getting was the fastest possible. Like a fool, I believed them.
23-05-2022 9:09 PM
Plusnet isn't THROTTLING you. Because I use to be with Plusnet for my FTTC 80/20 from 2014 to 2021. Always getting sync rate 79999/19999 with throughput speed of 74/19 because the openreach bras ip profile are 77.35Mb with PN current line speed of 77.3Mb with speedtest of 74/19 are spot on for the last 7 years. There is no throttling.
on
23-05-2022
9:15 PM
- last edited on
23-05-2022
9:25 PM
by
Call it what you like. Plusnet did everything they could and the best they managed in 5 years was 28mbps. Moved to another provider and straight away 34mpbs. That's all the evidence I need to see they were slowing me down.
Moderators Note: Full quote of preceding post remove as per Forum rules
