Router keeps resetting
Cianaciana52
For the past 10 days or so my router (hub one) keeps dropping off.
Is this a sign that my router is on the way out, or is it a problem with the Plusnet signal?  Anybody else experiencing this?
4 REPLIES 4
Fixes: 385
Re: Router keeps resetting
@Cianaciana52 welcome to the forums. Can you please explain exactly what you mean by 'dropping off'?
Cianaciana52
The router keeps going off randomly going throught the the green, orange and then back to solid blue.
This can happen a few times per day.
Fixes: 385
OK - just to give other Community members a chance to help, although it may not work:-
For Community members to be able to help, information from these two sites, as screenshots:-
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub would be a good starting point.
For the Hub One -
For the Hub Two -
If phone test is OK then take the front off your telephone master socket, you may need to remove two screws. In behind you will find the test socket. Plug a filter in here and connect that to your hub. If it’s still dropping out then report a fault at https://faults.plus.net.
Fixes: 1,662
I'm really sorry to see you're having connection issues. From what I can see we've booked a Qube engineer to look into the problem further for you this morning. Can you let me know how it goes?
