Contract Help!
- Re: Contract Help!
Re: Contract Help!
07-01-2015 2:58 PM
Chat Friday!
Re: Contract Help!
08-01-2015 11:54 PM
Quote from: Chris Don't worry about submitting a ticket. I'll do the reset and place the interleaving orders on Friday.
Hi Chris,
So it's Friday, I'll be awaiting the re-sync!
Regards.
Re: Contract Help!
09-01-2015 10:00 AM
Re: Contract Help!
09-01-2015 10:06 AM
Chow for now!
Re: Contract Help!
09-01-2015 11:00 AM
What I'm going to suggest is that I place a modify order to move you to ADSL2+ on 21CN, doing this will allow me to remove interleaving at the same time. I won't be able to make any changes to the SNR until this completes, but I can't do that at the moment anyway!
Let me know if this sounds ok to you and I'll get the order placed, they complete the next working day normally.
Re: Contract Help!
09-01-2015 11:09 AM
Given the reported 58dB attenuation, would ADSL2+ be a stretch too far? Would ADSL2 be more appropriate, as at 58dB this line will get nowhere near 8Mbps which could well be the reasoning for the ADSL(1) provision over CN21. That was how / why my 21CN line was origionally configured; it now hums nicely on adsl2 @3dB
Kevin
Re: Contract Help!
09-01-2015 11:11 AM
Re: Contract Help!
09-01-2015 11:36 AM
Re: Contract Help!
09-01-2015 12:00 PM
Cheers for the information. The other CP had lead me to understand that the modulation level on a line could be configured / ordered as ADSL2 or ADSL2+ - he declined my request for ADSL2+ on the basis that above 45dB the higher frequencies used by ADSL2+ would not be viable and attempting to do so would result in a degraded service compared to ADSL2.
May be I simply misunderstood what I think I heard. Will now erase the misconception.
Kevin
Re: Contract Help!
09-01-2015 12:03 PM
Re: Contract Help!
09-01-2015 1:11 PM
Quote from: Chris If ADSL2+ is too far then realistically the router should negotiate the connection to ADSL2.
This simply does not happen for certain lines - presumably at certain exchanges? Of course if it's provisioned as ADSL2+, then you can just set your modem/router to ADSL1, ADSL2 or ADSL2+ yourself.
Re: Contract Help!
09-01-2015 1:53 PM
jim:quote
Re: Contract Help!
09-01-2015 4:34 PM
Re: Contract Help!
09-01-2015 5:19 PM
Re: Contract Help!
10-01-2015 10:05 AM
