Can I have a static IP address?
jwm
Are PlusNet able to let me have a static/fixed IP address?
If so, how much does it cost and how do I get one!?
I'm no technical expert but it's part of setting up my CCTV camera which is connected to my router and I want to be able to look at my CCTV from the internet - I understand this is easier if your IP address doesn't keep changing.
Fixes: 153
Re: Can I have a static IP address?
it's available on certain accounts for a one off fee of £5
Adding or removing a Static IP
If you'd like to add or remove a Static IP please raise a Ticket or call our Support Team on 0800 432 0200 or 0345 140 0200
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
I added a static IP to mine through the member centre - it was one of the options on the account.
Fixes: 153
i think that has since gone, I copied that from my static ip page in the member centre Wink
Marksfish
The option to add a static ip to your account is available to action in the member centre, I have just done it (accidentally). It is under the Add ons tab and you click on apply now. BE CAREFUL though as there is no confirmation, once clicked, you have committed to a static ip which I think is wrong.
CS. Can this static ip be removed from my account please with no charge? I think it is wrong that one click commits you with no option to opt out of the transaction.
Mark
Ahh right - I did mine a couple of years ago - how time flies ......
Plusnet Staff
Plusnet Staff
@Marksfish  For accountability, can you please log that on the account for me? I can then get it done straight away.
 Tony
 Plusnet Support
Plusnet Staff
Plusnet Staff
Actually, I see you've already been in touch. We'll get it sorted for you.
 Tony
 Plusnet Support
Marksfish
Yes I had Tony, didn't want to clog the thread up. Thanks  Smiley
