Contract Help!
- Contract Help!
Re: Contract Help!
06-01-2015 11:43 AM
Moving the upstream SNR is unlikely to increase your upstream, which is the maximum.
Re: Contract Help!
06-01-2015 12:02 PM
3db snr on both downstream and upstream and interleaving off and then seeing how the connection copes like that, The engineer from Openreach said my line was good and I would agree so this would be the ultimate test.
Re: Contract Help!
06-01-2015 12:59 PM
Re: Contract Help!
06-01-2015 1:02 PM
Re: Contract Help!
06-01-2015 1:37 PM
1) I want to ensure your line is stable for a few days before making changes (so I'd like to wait a few days)
2) I can only do SNR changes once every ten days, so I need ensure everything is set correctly so as to avoid making things worse.
Re: Contract Help!
06-01-2015 2:27 PM
Hows the line looking so far?
Re: Contract Help!
06-01-2015 3:42 PM
Quote from: mlmclaren ...migh as well try getting the best out of it before stabilising it
Err no - you get it stable at 6dB and then try tweaking. If it is only stable with a target SNRM above 6dB one asks why. If it remains stable below 6dB then it is a bonus.
Re: Contract Help!
06-01-2015 5:27 PM
Re: Contract Help!
07-01-2015 2:38 PM
Re: Contract Help!
07-01-2015 2:41 PM
Re: Contract Help!
07-01-2015 2:43 PM
It should take effect within the next few minutes.
Re: Contract Help!
07-01-2015 2:45 PM
To confirm, you are change the target SNR for both downstream and upstream to 3db and changing my interleaving to fast path?
Re: Contract Help!
07-01-2015 2:51 PM
The reset I was doing would have reset your downstream SNR target to 3db. The lowest we can set the upstream to is 6db. If you wanted me to remove interleaving this needs to be done separately.
We'll need to take another look on Friday. Can you leave the router powered up and plugged in so we can see that it is stable over the next 2 days?
Re: Contract Help!
07-01-2015 2:53 PM
Well on Friday set Downstream to 3db and upstream to 6db ..
Can you do the change for the interleaving or do I need to submit a separate ticket?
Re: Contract Help!
07-01-2015 2:54 PM
