Can anyone help.. update or check firmware
- Re: Can anyone help.. update or check firmware
15-10-2010 8:13 PM
I have been asked by plusnet to check the firmware /drivers are most recent on my router. I don't know how to do this and can't find info on how to do it. if i don't do it then i may be charged £140 by BT if they come in to try and find why my speed is abysmal, and I haven't. Any help please before i go mad.
Message 1 of 9
(1,332 Views)
8 REPLIES 8
15-10-2010 8:20 PM
It would help if you told us -
1) The router manufacturer
2) The full model name/number
3) The hardware version (often shown on the model number label)
Message 2 of 9
(631 Views)
15-10-2010 8:28 PM
Thanks, is a thomson 585v7, Have found the software version 8.2.6.5. believe this is the latest one. so no need to update ( I think).
Message 3 of 9
(631 Views)
15-10-2010 10:50 PM
Hi rogadodge,
Yes, that is the latest version. If you should need to know how to do it we have a library article here which gives a step by step guide.
Jojo
Jojo
Message 4 of 9
(631 Views)
15-10-2010 10:58 PM
JoJo, don't you ever go home?
As I have the latest software , I am not going to reload them.....looks awfully complicated and i will probably mess it up.
Message 5 of 9
(631 Views)
15-10-2010 11:07 PM
Hi rogadodge,
I think you will be ok staying with that.
I am at home, I just know that some of you guys aren't able to do much in the day so I always like to pop on in the evening (unless I'm actually having a life - which I do occasionally, or watching X Factor) just to tie any loose ends and hopefully get you guys sorted.
Jojo
Jojo
Message 6 of 9
(631 Views)
16-10-2010 2:45 PM
Curiosity (cousin I think of McCavity ) stalks again.
Where does one find a ST585's firmware details? I can only find software version.
OT how many knew that Thomson changed its name to Technicolor earlier this year?
Message 7 of 9
(631 Views)
17-10-2010 12:55 AM
The Board Name is possibly the closest thing to firmware version (that's different on TG585 v8s for example). However the System Information page gives all the relevant information.
David
Message 8 of 9
(631 Views)
17-10-2010 2:25 PM
Thanks.
Message 9 of 9
(631 Views)
