Broadband Speed and Router
- Re: Broadband Speed and Router
04-03-2014 12:52 PM
04-03-2014 1:38 PM
Ok I will get the iMac down to the router and do a test for you....
I do understand that Ethernet can be better. But why have I had 17mb for a good few weeks since I've upgraded to 21Cn and then all the sudden drops
04-03-2014 1:40 PM
04-03-2014 1:47 PM
04-03-2014 1:48 PM
Like I said ever since next door join you I've notice poor services but i wouldn't of though this effected anything but need this sorting please
04-03-2014 1:53 PM
It could be something as simple as your neighbour is now using wireless on the same channel as you and it is causing your speed problems. I get very variable speeds on my wireless during the day and especially in the evening when my speed can drop to 7 or 8Mb (down from 40+) when the neighbours are all on their wireless. My wired connection stays relatively stable though.
04-03-2014 2:04 PM
I cant really keep this on wired as the router in a room where it awkward. But as I say I have never had wireless problems...
04-03-2014 2:06 PM
04-03-2014 2:07 PM
04-03-2014 2:11 PM
Quote from: rookey But as I say I have never had wireless problems...
...until your neighbor turned on their new router.
Just because they are on different channels doesn't mean there is no possibility of interference.
Are you certain that last test was via ethernet? I'm surprised that the ping time didn't change at all, I would have expected it to be a bit lower via ethernet. Did you physically turn off the wireless access?
04-03-2014 2:13 PM
There you go your surprised see I've a problem as I use to get ping 18 via wifi..
04-03-2014 2:15 PM
04-03-2014 2:16 PM
04-03-2014 2:22 PM
04-03-2014 2:27 PM
