BT Speedtester - is it broken?
Oldjim
Resting Legend
Fixes: 63
Re: BT Speedtester - is it broken?
The duff results are, or seem to be, specific to 21CN in any of it's flavours (ADSL1, ADSL2 and ADSL2+)
I am on 21CN ADSL1
itsme
Because of another thread regarding the Service ID I though I run the Speedtester just entering my Service ID, as I do know mine. The returned result looks okay so I imagine the problem is with the database of telephone numbers to Service ID.
Just to explain how I see the Service ID. Using MAC address and IP address as a comparison the Service ID = MAC address and the Telephone number=IP address. So the Service ID is fixed to the hardware.
Mad_Moggies
Ah, I see what you were getting at, Jim. Thanks for the clarification as to what's affected.
Plusnet user since November 2003
Full Fibre since September 2023
Mac OS14 and Firefox user with latest versions of both
Oldjim
Resting Legend
Fixes: 63
I checked using the Service ID only with no cookies and the result was also wrong - this was on Sept 13th
itsme
You right. I must have been lucky the once getting the test results that agree with my modem. Suppose having a banded profile increases the coincident factor.  Roll_eyes
woodsider
Sorry Mad Moggies. I've been out enjoying the great weather today.
I had assumed 20CN, but have never thought to check it out. Sorry.
woodsider
Max and IPstream. That'll be 20CN, won't it?
pierre_pierre
32110
Well the upload details seem OK. Performed at 8:55pm.
pierre_pierre
but the profile wasnt
bobpullen
Fixes: 316
Have had a follow-up call with BT and the Speedtester developers today. They've identified a problem with the code that they think is causing the incorrect IP profiles and speed ranges that are being returned for 21CN circuits. A fix is being rolled tonight that should hopefully sort this out.
I'm led to believe that the misreported sync speeds may be due to another issue, so tonight's fix might not address this particular aspect of the problem.
Can those of you on 21CN connections run some tests for me after 10pm tonight and let me know how you get on?
Eager to find out whether or not tonight's code changes have helped.
Thanks.
Oldjim
Resting Legend
Fixes: 63
Test at 22.10
Speeds are correct but IP profile is actually 3,500 according to the Plusnet systems
Edit - just had a discussion with Plusnet - my IP profile is showing as 3000 on the BT system (this was due to a 15 minute drop in sync speed 3 days ago) but it didn't report to the Plusnet system
pierre_pierre
22:15 Mine is still not correct
pierre_pierre
test this morning 21cn
pittdj
A 21CN BT speedtest at 0750 today, Tues 28th.
It is definitely still broken as far as the configured IP profile goes as the actual speed achieved exceeded that value. (The PN profile is 8000kb/s, as expected for a sync of 9363kb/s.)
Download speedachieved during the test was - 7432 Kbps
For your connection, the acceptable range of speedsis 1000-7150 Kbps.
Additional Information:
Your DSL Connection Rate :9363 Kbps(DOWN-STREAM), 1095 Kbps(UP-STREAM)
IP Profile for your line is - 7150 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 17.86:24.81:57.33 (SBE:NBE:PBE)
