BT Speedtester - is it broken?
- Re: BT Speedtester - is it broken?
25-09-2010 1:20 PM
I am on 21CN ADSL1
25-09-2010 1:44 PM
Just to explain how I see the Service ID. Using MAC address and IP address as a comparison the Service ID = MAC address and the Telephone number=IP address. So the Service ID is fixed to the hardware.
25-09-2010 1:49 PM
Full Fibre since September 2023
Mac OS14 and Firefox user with latest versions of both
25-09-2010 1:52 PM
25-09-2010 4:37 PM
25-09-2010 6:33 PM
I had assumed 20CN, but have never thought to check it out. Sorry.
25-09-2010 7:45 PM
25-09-2010 7:51 PM
25-09-2010 8:57 PM
25-09-2010 9:25 PM
27-09-2010 8:11 PM
I'm led to believe that the misreported sync speeds may be due to another issue, so tonight's fix might not address this particular aspect of the problem.
Can those of you on 21CN connections run some tests for me after 10pm tonight and let me know how you get on?
Eager to find out whether or not tonight's code changes have helped.
Thanks.
27-09-2010 10:16 PM
Speeds are correct but IP profile is actually 3,500 according to the Plusnet systems
Edit - just had a discussion with Plusnet - my IP profile is showing as 3000 on the BT system (this was due to a 15 minute drop in sync speed 3 days ago) but it didn't report to the Plusnet system
27-09-2010 10:20 PM
28-09-2010 7:46 AM
28-09-2010 8:01 AM
It is definitely still broken as far as the configured IP profile goes as the actual speed achieved exceeded that value. (The PN profile is 8000kb/s, as expected for a sync of 9363kb/s.)
Download speedachieved during the test was - 7432 Kbps
For your connection, the acceptable range of speedsis 1000-7150 Kbps.
Additional Information:
Your DSL Connection Rate :9363 Kbps(DOWN-STREAM), 1095 Kbps(UP-STREAM)
IP Profile for your line is - 7150 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 17.86:24.81:57.33 (SBE:NBE:PBE)
