BT Home Hub 5
- Re: BT Home Hub 5
- « Previous
- Next »
Re: BT Home Hub 5
24-01-2014 2:59 PM
Re: BT Home Hub 5
24-01-2014 3:08 PM
Re: BT Home Hub 5
25-01-2014 8:49 PM
Re: BT Home Hub 5
26-04-2014 7:55 AM
Re: BT Home Hub 5
26-04-2014 8:55 AM
However - I have AC mode disabled as I thought it was buggy (my macbook doesn't do AC at all, nor does any other device in my house). Might be worth a try.
I also have fixed channels set on the wifi, and WPS disabled, and disabled the smart wifi function.
I don't use the HH5 as a router - just as a fast access point. I do wonder if the performance of the wifi is negatively impacted by using the router side of the device - I always thought it might be a factor.
Re: BT Home Hub 5
26-04-2014 12:51 PM
Re: BT Home Hub 5
22-05-2014 4:30 PM
Re: BT Home Hub 5
05-07-2016 7:14 PM - edited 05-07-2016 7:17 PM
Re: BT Home Hub 5
05-07-2016 7:22 PM
Are you sure your user name is in the format yourusername@plusdsl.net ? It took me a couple of goes first time I did it, but it works fine for me. Also doing it whilst disconnected can also help.
Re: BT Home Hub 5
05-07-2016 7:30 PM
Re: BT Home Hub 5
05-07-2016 7:32 PM
Just press the disconnect button on the router user interface and try again.
Re: BT Home Hub 5
05-07-2016 7:35 PM
- « Previous
- Next »
