BT Home Hub 5
- BT Home Hub 5
BT Home Hub 5
01-11-2013 10:46 PM
Has anyone managed to try out the bt home hub 5 on plusnets fttc service and how did the combined unit perform as im looking at purchasing one direct from the bt store but would like to know are there any pro's and con's IE are the sync stats viewable since it's a combined unit .
Re: BT Home Hub 5
03-11-2013 12:48 AM
Re: BT Home Hub 5
03-11-2013 8:13 AM
here is a guide on how to set up the hub, that I created on Plusnet. It should work on hub 5 even though it is appointed to the earlier models
http://community.plus.net/forum/index.php/topic,113872.0.html ; (another thread)
exact same information but from library
http://community.plus.net/library/hardware/using-a-bt-homehub-3-or-2-on-plusnet-adsl-or-fttc/
Re: BT Home Hub 5
03-11-2013 8:20 PM
Re: BT Home Hub 5
04-11-2013 5:25 PM
So by the time I have one you would have probably set one up
I am getting mine for £45 from BT (can't remember exact price but around that) I am an existing BT customer on infinity 2 (see my sig )
Re: BT Home Hub 5
04-11-2013 6:42 PM
Re: BT Home Hub 5
04-11-2013 6:58 PM
Re: BT Home Hub 5
04-11-2013 11:23 PM
Re: BT Home Hub 5
05-11-2013 8:32 AM
Re: BT Home Hub 5
05-11-2013 4:02 PM
Re: BT Home Hub 5
05-11-2013 9:44 PM
stripped the way off topic posts
Re: BT Home Hub 5
05-11-2013 9:57 PM
Re: BT Home Hub 5
06-11-2013 6:27 AM
Re: BT Home Hub 5
06-11-2013 7:21 AM
Re: BT Home Hub 5
06-11-2013 8:59 PM
dick:quote
