0.79 down speed
- 0.79 down speed
Re: 0.79 down speed
05-11-2014 5:12 PM
Re: 0.79 down speed
06-11-2014 1:11 AM
Downstream Upstream
SNR Margin
2.4 8.8 db
Line Attenuation
61.3 38.5 db
Data Rate
2435 467 kbps
Max Rate
2672 468 kbps
CRC
18403 0
After Reset
Downstream Upstream
SNR Margin
6.0 8.9 db
Line Attenuation
63.0 38.4 db
Data Rate
2205 544 kbps
Max Rate
2636 576 kbps
CRC
26 0
Download speed achieved during the test was - 1.75 Mbps
For your connection, the acceptable range of speeds is 0.8 Mbps-2 Mbps.
IP Profile for your line is - 2.15 Mbps
Upload speed achieved during the test was - 0.43Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
So hopefully my plusnet profile can be popped up to the bt IP profile. Hopefully then I will receive something similar to what I was getting from day one of plusnet many moons ago
Re: 0.79 down speed
06-11-2014 8:37 AM
So what you need to do is, around the middle of the day, certainly a good hour after sunrise and a good hour before sunset, is pull the POWER plug on your modem/router. Stay off-line for around 20 minutes and then plug it back in again.
Post the new stats.
As far as RSL (RouterStatsLite) not graphing goes, not urgent, but did you check it was the V3 modem/router and did you leave RSL running long enough to see the plotting - you could always do a screen grab of the Noise Margin Graph at some point and I can see if I can spot anything obvious.
Re: 0.79 down speed
06-11-2014 12:47 PM
Downstream Upstream
SNR Margin
2.4 9.3 db
Line Attenuation
61.3 38.4 db
Data Rate
2510 440 kbps
Max Rate
2784 440 kbps
CRC
1175 0
Download speed achieved during the test was - 2.07 Mbps
IP Profile for your line is - 1.95 Mbps
Upload speed achieved during the test was - 0.38Mbps
Re: 0.79 down speed
06-11-2014 1:23 PM
What I did notice from your previous stats and now was that your Upstream Target SNRM looks to be 9dB and that needs changing to 6dB - don't know if that can be done whilst the line is in training (from the reset) but if the profile needs kicking by BTw then that can be fixed at the same time if Plusnet advise BTw. (I'm sure Tony is keeping an eye on things).
Re: 0.79 down speed
06-11-2014 6:28 PM
SNR Margin
1.7 5.2 db
Line Attenuation
61.3 38.4 db
Data Rate
2510 440 kbps
Max Rate
2828 408 kbps
CRC
14112 0
Download speed achieved during the test was - 2.21 Mbps
IP Profile for your line is - 2.21 Mbps
Getting there
Re: 0.79 down speed
07-11-2014 10:30 AM
I've replied to your PM about this "4th cable".
Re: 0.79 down speed
07-11-2014 10:09 PM
SNR Margin
0.2 8.8 db (Downstream varies from 0.2 - 1.2)
Line Attenuation
61.3 38.4 db
Data Rate
2510 440 kbps
Max Rate
2844 428 kbps
CRC
41677 0
Download speed achieved during the test was - 2.12 Mbps
Maybe with it settling without disconnection I might be able to achieve my regular speeds before the botch job install my friend had done (thanks BT subcontractor) Speeds which were around 2.6mb, but either way I am pretty happy with where it is at so far. I just hope it stays that way.
Re: 0.79 down speed
07-11-2014 11:09 PM
Re: 0.79 down speed
26-11-2014 8:29 PM
For a while my internet has been fairly stable and I had been receiving around 1.8mb connection which I suppose is ok. but I wanted to update you on my current statistics as I have had a few drops today.
Downstream Upstream
SNR Margin
0.1 5.1 db
Line Attenuation
61.3 38.2 db
Data Rate
2727 627 kbps
Max Rate
9716 600 kbps
CRC
685 65504
As you can see the SNR is really low... a tadge too low and my Max rate keeps jumping from around 3500 to over 9000.
I know BT have had the new fttc box installed which will eventually once active give us our FTTC internet, but I am unsure if maybe they are running some sort of tests on the lines, which might be causing these issues. In a way I hope they are as I would love to see the new internet coming in :)... finally be able to use Youtube above 360 😛 with more than 1 computer online 😛
I had also run a BT speedtest which told me that I was receiving 1.67MB download and a BT IP profile of 2.44MB.
Many Thanks.
Re: 0.79 down speed
26-11-2014 8:43 PM
Have you done the Quiet Line Test 17070 option 2, when it's this low just to check the line is not noisy?
Check your Current Line speed (Login required). If that is down, maybe you had a lower sync speed at some point recently and it hasn't gone back up yet to match the current 2.4Mbps.
Re: 0.79 down speed
26-11-2014 9:29 PM
Current line speed:1.6 Mb
I haven't done a quiet line test, reason being is that I have a wireless phone. Haven't had a cordless one in forever. Suppose it might be worth having one though. I will have a check though.
Re: 0.79 down speed
26-11-2014 9:40 PM
Re: 0.79 down speed
27-11-2014 6:00 AM
(When you have sync speed changes, you need to keep a check on your BT IP Profile and your Current Line speed to make sure things update correctly within a reasonable period).
Re: 0.79 down speed
27-11-2014 5:30 PM
So the profile has risen, but the disconnection issue is occurring too frequently and I would rather my net not get driven all the way back down to 1.3mb
Download speedachieved during the test was - 2.41 Mbps
IP Profile for your line is - 2.24 Mbps
Current line speed:2.6 Mb
Downstream Upstream
SNR Margin
0.1 5.7 db
Line Attenuation
63.0 38.2 db
Data Rate
2667 648 kbps
Max Rate
9532 656 kbps
CRC
4562 65502
If this means anything to anyone:
Router System Log
11/27/2014 16:59:7> WANIPConnection->GetGenericPortMappingEntry failed
11/27/2014 17:17:5> SNMP TRAP 2: link down
11/27/2014 17:17:10> ppp_ready: ch:804eec58, iface:804648a0
11/27/2014 17:17:11> SNMP TRAP 3: link up
11/27/2014 17:17:11> Accept() fail
11/27/2014 17:17:50> dynDNSOrgLogin:Error = -8, retCode
11/27/2014 17:19:9> WANIPConnection->GetGenericPortMappingEntry failed
