0.79 down speed
- 0.79 down speed
Re: 0.79 down speed
28-11-2014 9:13 AM
Re: 0.79 down speed
28-11-2014 3:36 PM
Would try checking out the event log again but can't even log into the router. just hanging at 'waiting for 192.168.1.1'.
I'll post it again when it lets me in.
Current line speed:2.3 Mb (a slight drop which hopefully is a good thing)
Download speedachieved during the test was - 2.22 Mbps
For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
IP Profile for your line is - 2.46 Mbps
I'm happy with those results, just need to be able to log onto the router to see those stats. I would rather not have to reboot the router unless needed. I'll check after I've made food (fingers crossed its working by then)
Re: 0.79 down speed
28-11-2014 3:40 PM
Re: 0.79 down speed
02-12-2014 3:50 PM
So now my bt wholesale tests are coming up with 1.3mb again... woohoo
BT
1. Best Effort Test:
Download Speed : 1.32 Mbps
2. Upstream Test:
Upload Speed : 0.39 Mbps
PlusNet
Current line speed:1.5 Mb
Router
Downstream Upstream
SNR Margin
8.1 4.6 db
Line Attenuation
61.3 38.2 db
Data Rate
2137 584 kbps
Max Rate
2524 588 kbps
CRC
87 0
Re: 0.79 down speed
02-12-2014 3:59 PM
I'd pull the power plug (bearing in mind you haven't got a Disconnect button for the PPP Internet session) and stay off for 10 minutes and then power up again. Post the new stats.
Re: 0.79 down speed
02-12-2014 4:36 PM
BT
Download Speed : 1.47 Mbps
2. Upstream Test:
Upload Speed : 0.44 Mbps
plusnet
Router
Downstream Upstream
SNR Margin
7.5 5.1 db
Line Attenuation
63.0 38.2 db
Data Rate
1881 659 kbps
Max Rate
2040 640 kbps
CRC
15 0
Re: 0.79 down speed
02-12-2014 7:36 PM
btw, did you ever check out that extra cable that you thought went next door?
Re: 0.79 down speed
03-12-2014 2:33 PM
It looks as though something changed on the 2nd as the Target SNRM is set to 6 Up and 6 Down but according to the KBD testing the line is sat at 6 Up and 3 Down at the moment. On the plus side, the DLM has pushed the speed up to almost 1.7mbps from the 1.2mbps it was at previously so it seems to be recovering from the drop of the phone service.
An SNR reset may well be in order however I would be a little hesitant to place this at the moment given that the speed seems to be recovering.
Re: 0.79 down speed
03-12-2014 2:43 PM
@alliasjay, remind us who your line rental is with?
Re: 0.79 down speed
05-12-2014 6:05 PM
Re: 0.79 down speed
05-12-2014 11:47 PM
I think the next move should be run a quiet line test (17070 option 2) if it's still noisy get back to Plusnet, but it might be good to try a mid-day power down for 10 minutes then resync and see if a better speed can be achieved.
Re: 0.79 down speed
09-12-2014 10:12 AM
Re: 0.79 down speed
09-12-2014 10:40 AM
Re: 0.79 down speed
10-12-2014 9:36 AM
Oddly, on http://dslchecker.bt.com he has significantly improved: WBC ADSL 2+ Up to 3 -- 1.5 to 5.5 Available but the actual speed is still low
Re: 0.79 down speed
10-12-2014 10:45 AM
