PC or laptop?? that's the question!
- Re: PC or laptop?? that's the question!
04-10-2013 12:13 PM
Quote from: hollytree Hmmmm, I do believe Promod and Sprite between them have cracked this conundrum.
Naturally.. because I'm always right
![Wink Wink](/html/@ED8EAB3707DE077FFF94EEBAB958E3C6/images/emoticons/wink.gif)
(just remember to tell OldJim that for me ok? ;D)
04-10-2013 6:16 PM
04-10-2013 9:29 PM
Quote from: MrT Going back to your original post:
Quote from: hollytree Thinking of replacing my ancient Dell desktop. But can't make up my mind what kind of PC I should get!
What are your thoughts?
Does your desktop do everything that you want from it?
Is it a case of wanting a similar PC but one that is easily transportable between rooms?
If the answer to both of the above is yes then a modern laptop with a reasonable spec will do want you want.
@ Mr T : thanks for bringing the subject back to my original query!
![Smiley Smiley](/html/@39650D28FE4EA73A5BA77CFD0A477003/images/emoticons/smiley.gif)
Incidentally, I've just been looking online at something called a portable, all-in-one desktop PC - never heard of this and wondering what you and others think of them?
![Undecided Undecided](/html/@B2520ED9758574DA4DA10314C4B1AB94/images/emoticons/undecided.gif)
05-10-2013 8:44 AM
![Tongue Tongue](/html/@ABEEE74AC8816312151E3310999DC0DF/images/emoticons/tongue.gif)
05-10-2013 11:41 AM
![Huh Huh](/html/@E2297E1574AC8AB2FE5882A8865382BF/images/emoticons/huh.gif)
dick:quote
05-10-2013 1:50 PM
05-10-2013 1:56 PM
05-10-2013 3:54 PM
I have no idea what your budget is.
You can get a very good laptop for a lot less than £1000 and have plenty of money left over to add things like a wireless keyboard if you prefer.
05-10-2013 10:44 PM
You've already said you find laptops limiting, so it's the only solution...if your budget could stretch to getting two...or get one now and the other later.
06-10-2013 2:31 PM
![Sad Sad](/html/@5863905B9AC6EE4F2B28C1A2965ABC0C/images/emoticons/sad.gif)
@Mr T: another good point ... my budget is only £700, im afraid.. and a desktop - type keyboard is essential for me
@ Glenn: I can probably get around the lack of a separate keyboard by getting either a wired or plug-in one for a laptop. Your suggestion for 2 separate PCs , one in each room, makes sound sense but my wife probably wouldn't wear it in the living room and neither wd our bank manager :(.
Am I right in thinking that it's simply not possible to have, for instance, your desktop computer upstairs and your keyboard, screen, mouse etc downstairs or upstairs as required?? That way, I would just need to shift the peripherals around as and when needed. Could they be connected wirelessly over that distance? And through solid brick walls? Or with cabling? As you can no doubt tell, this is a totally unfamiliar knowledge area for me.
![Embarrassed Embarrassed](/html/@6CEFBAD878A40FF337662307A879A7FD/images/emoticons/embarrassed.gif)
06-10-2013 2:59 PM
You could run your desktop headlessly using a modest computer downstairs
if you were OK with low-grade screen output (no video pictures)!
The upstairs PC would be doing all the work.
06-10-2013 3:22 PM
06-10-2013 11:37 PM
06-10-2013 11:52 PM
Buy a new PC and put that in your prime most used location. But keep your old Dell somewhere else for the more easy mundane tasks.
And you could also improve the old Dell. A new keyboard and plenty of good cheap screens on ebay.
A cheap upgrade and a new PC.
07-10-2013 1:26 PM
Quote from: Sprite You'll regret asking that.. now he's going to go on his anti windows / pro linux campaign
Try VNC or similar - works on all platforms.
