Start Ups on XP
penneck
Start Ups on XP
My pc has Win XP Pro. Should it have a list of processes that start running when I boot the pc up (a list that I can go into and stop anything that I don't want to start), and where would I find it?
Thanks for your help
10 REPLIES 10
MrT
Re: Start Ups on XP
With my Windows XP Home, I use Autoruns available from http://technet.microsoft.com/en-us/sysinternals/bb963902(v=msdn.10).aspx  Smiley
2u2me
Re: Start Ups on XP
Hia, Another program you could consider is CCleaner, you can stop processes starting  up via its tools section
Cheers
thejudge
Re: Start Ups on XP
Control Panel > Administrative Tools > Services. What shows as 'Automatic' will start at bootup.
7up
Fixes: 17
Re: Start Ups on XP
OR Start > Run > msconfig will also show you a list of things running on startup including the services. On win98 it's msinfo32 (can't remember WinMe) but those older systems didn't have services afaik.
PeterLoftus
Fixes: 5
Re: Start Ups on XP
ctrl+alt+del start task manager select services  Smiley
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
7up
Fixes: 17
Re: Start Ups on XP
That only lets you crash them, not disable them.
198kHz
Fixes: 41
Re: Start Ups on XP
Of all the methods, I find Autoruns to be the easiest to use.
Select the 'Logon' tab for startups,
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
Thunderclap
Re: Start Ups on XP
Quote from: MrT
Indeed, Autoruns from SysInternals is a really great tool for looking under the hood. It's amazing how much stuff loads on startup - including all of that bloatware from Sony/Dell/HP etc. With Autoruns you can switch it out.
The other most usefull gadget from SysInternals is Process Explorer
This shows Windows processes in real time as they are created, live and decay. You can identify which DDLs each process uses too. Or you can just sit their and watch the pretty colours. Just one caveat is Process Explorer may trip an Anti Virus alarm - it requires higher privilages than the current user may have. But that's not a problem as SysInternals stuff is trusted.
Process Explorer : http://technet.microsoft.com/en-us/sysinternals/bb896653
Another cool one to try is TCP View which lets you see your computer's TCP/UDP endpoints. Very handy for seeing where all that internet traffic is really going. http://technet.microsoft.com/en-us/sysinternals/bb897437
Cool
billnotben
Re: Start Ups on XP
To see what services are doing and whether you really need them or can disable them have a good read here.
http://www.blackviper.com/service-configurations/black-vipers-windows-xp-x86-32-bit-service-pack-3-s...
penneck
Re: Start Ups on XP
Thanks to all for your help
