BTw Performance Test via Further Diagnostics
goldenfibre
Seasoned Pro
Fixes: 12
Chris Parr - please report BTw performance test with further diagnostics is no longer working see screenshot below:
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
126 REPLIES 126
Melancholie
Re: BTw Performance Test via Further Diagnostics
FYI - There is a rate limit on the amount of times the test can be run and further diagnostics path followed.
If you've been obsessively speed testing and checking, as going by the congestion thread you might have, you may have fallen foul of it - leave the Wholesale speedtest's further diagnostics path alone for at least 12 hours and ideally 24.
goldenfibre
Seasoned Pro
Fixes: 12
^^ to be honest my last time checking on BTw speedtest was a few weeks ago. It's never work since!
KevinA
I too have the error and can confirm it just stopped working about a week ago..
PeeGee
Haven't run the diagnostics for some time, but it worked fine a few moments ago.
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
jelv
Fixes: 10
Likewise. Took the usual ages to come back, but it worked.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Chris
Legend
Fixes: 169
@goldenfibre
Thanks for flagging this up.
@kevinandrews
Is it the same error as goldenfibre?
ITWorks
Fixes: 9
@ Chris
I have the same issue on my line (ADSL) as goldenfibre , the further diagnostics has not worked for me since the beginning of January 2014.
Regards
Mike
thesawdust
working fine here, don't ever use this website personally because i've a stable connection  Cool
goldenfibre
Seasoned Pro
Fixes: 12
@ Chris. My BTw last working was last November 2014 (end of Nov)
30FTTC06
Fixes: 4
Kevin
Hasn't worked for me either......
Kevin.
Anotherone
Champion
Fixes: 21
@Chris,
Working for me on ADSL but I have come across numerous threads on this forum where people can't get the Further Diagnostics to run, and it's been like that for far too long. The last I heard about this problem - I was told Andy Thompson was kicking BTw but that was months ago. The last time its problems were actually resolved was when Chris Pettitt took BT to task and that might have been a year ago, that only lasted until BTw yet again changed something.
goldenfibre
Seasoned Pro
Fixes: 12
^^ Agree 100% with this. BTw have mess this up again!
deathtrap
Working for me, It's like the last time this happened only some customers where affected  a bit odd really
