BTw Performance Test via Further Diagnostics
- BTw Performance Test via Further Diagnostics
Re: BTw Performance Test via Further Diagnostics
20-01-2015 8:44 AM
Phil
20-01-2015 10:43 AM
20-01-2015 4:20 PM
Quote from: Chris @kevinandrews
Is it the same error as goldenfibre?
I can confirm its the identical error message..
20-01-2015 4:25 PM
goldenfibre
KevinAndrews
I.T.Works
Kevin
TEST WORKS
PeeGee
Jelv
thesawdust
11110_110
Anotherone
deathtrap
20-01-2015 4:29 PM
I'm going to try and find out who Chris Pettitt spoke to last time about this.
20-01-2015 7:21 PM
20-01-2015 7:34 PM
20-01-2015 11:43 PM
Appreciate it's been a while since I last looked at this!
Steve Crookes is also investigating too. Sorry for any delay, but please leave it with us for further investigation.
21-01-2015 6:09 AM
21-01-2015 12:04 PM
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
21-01-2015 12:18 PM
It's been working OK for the last few months for me (ADSL), but on a few occasions in the past the further diagnostics have refused to play no matter how long I waited, producing the error message already referred to instead.
21-01-2015 1:53 PM
PN Current line speed: 77.4 Mb - date of last stamped: 17-10-14 @ 06:21
BT IP Profile: 77.42 Mb date of last stamped: 16-10-14 @ 23:57
21-01-2015 1:56 PM
21-01-2015 6:17 PM
Could not using the bt openreach cpe have something to do with this for the fftc users?
Quote from: goldenfibre Why can't Plusnet add on the member account like this below:
Something like this Max ?
At a click of a button in clueless,,,,,,
Quote BT Test E2E Access Test/DCN:Inconclusive Unble to find fault in BTW. OR test rejected/Timed Out.
Down: (79.9/79.6/79.8) Up: (20.0/20.0/20.0) tx rate Tx rate (adjusted)
NA 0.128M-80M Downstream, Interleaving Off - 0.128M-20M Upstream, Interleaving Off
As I said many times aaisp is ideal for the discerning users like goldenfibre
22-01-2015 2:33 PM
