online streaming failing
jasonfreeman
Re: online streaming failing
Can someone from plusnet post my line connection over the past week please
adamwalker
Fixes: 221
Sure and sure:
<img src="http://community.plus.net/visualradius/generated/image13923071556618.png"/>
 Adam Walker
jasonfreeman
see how my connection is ok now my broadband has been plugged in the test socket for 48 hours
jasonfreeman
what could i do to make my connnection better without using the test socket?
picbits
The test socket basically disconnects the rest of the telephone wiring from your house i.e. your telephone extension sockets.
Do you have any other phones  / Sky box or anything plugged into these extensions and if so, do they each have a microfilter on them ?
jasonfreeman
i don't have any extensions or anything plugged in
Oldjim
Resting Legend
Fixes: 63
Quote from: jasonfreeman
No it isn't - read the graph again
jasonfreeman
What is wrong from the graph then?
Oldjim
Resting Legend
Fixes: 63
Look at the dates - you weren't on line without interruption for 48 hours in the test socket at the time the graph was generated - there were 3 disconnections in the previous 48 hours so not much different from previously
jasonfreeman
What does that mean then? What could be wrong?
picbits
To me, that graph says you had 4 disconnections on the 11th and one on the 12th.
picbits
Have you had your line fault sorted yet ?
Did you manually turn off / reboot or reset your router during those days ?
jasonfreeman
Well I was doing the test socket for 48 hours then get an opinion and if they think its not normal then an engineer will have to come and try find the fault
Oldjim
Resting Legend
Fixes: 63
I don't say it isn't normal given the appalling weather conditions
I am saying that there is no significant difference between the test socket and not the test socket
Have you reported a voice fault as you were advised to do on the 9th Feb
jasonfreeman
What is your opinion of my connection whilst connected to the test socket?
