online streaming failing
- online streaming failing
06-02-2014 4:21 PM
Re: online streaming failing
06-02-2014 4:31 PM
Do you have another computer you can test this on to rule out a machine issue ?
What kind of device are you using to try and stream the BBC iPlayer ?
06-02-2014 4:41 PM
06-02-2014 4:50 PM
It could also be an issue with your broadband but until you rule out the hardware, it's a little tricky to tell.
06-02-2014 4:54 PM
06-02-2014 5:00 PM
06-02-2014 5:01 PM
06-02-2014 5:03 PM
06-02-2014 5:08 PM
Thanks pmarti22
06-02-2014 5:08 PM
Description Speed Status
Your connection 14730 kbps
Your available bandwidth is 14730 kbps.
n/a
TV - HD 3500
Uses 23% of your available bandwidth.
passed
TV 1500
Uses 10% of your available bandwidth.
passed
TV 800
Uses 5% of your available bandwidth.
passed
TV 500
Uses 3% of your available bandwidth.
passed
Radio 128
Uses 0% of your available bandwidth.
passed
see i don't understand why its buffering or failing
06-02-2014 5:22 PM
Your connection 16244 kbps
Your available bandwidth is 16244 kbps.
n/a
TV - HD 3500
Uses 21% of your available bandwidth.
passed
TV 1500
Uses 9% of your available bandwidth.
passed
TV 800
Uses 4% of your available bandwidth.
passed
TV 500
passed
Radio 128
passed
06-02-2014 5:33 PM
06-02-2014 5:46 PM
Quote from: Chris Sorry, thought I'd pasted the link in!
Thanks pmarti22
Your welcome.
06-02-2014 5:47 PM
I moved to ptn after getting freezing on pcl 8 days, 8:39:51 ago, been fine since
Your connection 17210 kbps
Your available bandwidth is 17210 kbps.
n/a
TV - HD 3500
Uses 20% of your available bandwidth.
passed
TV 1500
Uses 8% of your available bandwidth.
passed
TV 800
passed
TV 500
Uses 2% of your available bandwidth.
passed
Radio 128
06-02-2014 5:52 PM
