online streaming failing
Chris
Legend
Fixes: 169
Re: online streaming failing
We've not replied as Oldjim has been helping you, that's the beauty of a forum you don't specifically need a staff member to reply for some issues.
Oldjim
Resting Legend
Fixes: 63
Did you spot my edit
jasonfreeman
Yes I did spot your edit but I already tried that suggestion yesterday and still no luck Sad
Oldjim
Resting Legend
Fixes: 63
Do you have a friend where you can take your laptop and see if you can stream there
Fixes: 162
Quote from: jasonfreeman
but i don't understand why its buffering and failing then?
Line errors?
What are your router sats like?
jasonfreeman
not now i don't and how do i find out my router stats?
Fixes: 162
This page - http://www.kitz.co.uk/adsl/frogstats.php - has the instructions you need for a good number of popular routers.
jasonfreeman
These are my router stats:
Uptime: 1 day, 21:07:27
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1,136 / 20,564
Data Transferred (Sent/Received) [MB/GB]: 141.15 / 1.99
Fixes: 162
Jason,
Does your router provide more details pease?
Need to see attenuation, noise ratio and error counts to assist further.
jasonfreeman
how do i find the other information needed?
Fixes: 162
Depends on your router.  If is the TG582n supplied by PN, click details towards the top right of the stats page.
jasonfreeman
Uptime: 1 day, 21:26:12
Data Transferred (Sent/Received) [MB/GB]: 141.97 / 1.99
Output Power (Up/Down) [dBm]: 12.2 / 20.8
Line Attenuation (Up/Down) [dB]: 4.9 / 7.0
SN Margin (Up/Down) [dB]: 5.9 / 6.1
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Link (Remote): -
Error Seconds (Local/Remote): 13 / 0
FEC Errors (Up/Down): 837 / 22,222,806
CRC Errors (Up/Down): 1,275 / 13
HEC Errors (Up/Down): 975 / 88
Fixes: 162
OK, if I take these figures at face value, then you are nearly living in the exchange - 0.5km away.  Your synch rate is down 20% on forecast for the attenuation figure.  Error counts are high, but I cannot say if they are significant, but for the reported up time the DS FEC errors are around an average of 140 per second.  Some suggest that the TG582n can over report FECs, though I have seen TGs ground to a stand still serving FECs.
Is your router connected into the master socket?  Is there any noise on the line (dial 1700 option 2).  Do you have a new filter you could try?
Oldjim
Resting Legend
Fixes: 63
That may be the problem - the FEC in relation to the amount downloaded looks very high
This is from my router
Uptime: 2 days, 5:29:58
Data Transferred (Sent/Received) [MB/GB]: 272,02 / 1,99
FEC Errors (Up/Down): 4.276 / 1.366.839
By comparison you have 16 times the number of FEC for less uptime and about half the usage
If Plusnet increase the default noise margin to 9dB it will slightly reduce the speed but hopefully will  reduce the FEC count
In the meantime what is the noise margin late at night
jasonfreeman
to be honest i wouldn't want my speed reduced and at night i'm not really sure and yes the router is connected to the master socket (its the only socket i have in my place) and i don't have a home phone to test the noise
