online streaming failing
- Re: online streaming failing
07-02-2014 4:45 PM
07-02-2014 4:45 PM
07-02-2014 4:51 PM
07-02-2014 5:14 PM
07-02-2014 5:16 PM
Quote from: jasonfreeman but i don't understand why its buffering and failing then?
Line errors?
What are your router sats like?
07-02-2014 5:18 PM
07-02-2014 5:22 PM
This page - http://www.kitz.co.uk/adsl/frogstats.php - has the instructions you need for a good number of popular routers.
07-02-2014 5:34 PM
Uptime: 1 day, 21:07:27
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1,136 / 20,564
Data Transferred (Sent/Received) [MB/GB]: 141.15 / 1.99
07-02-2014 5:37 PM
Does your router provide more details pease?
Need to see attenuation, noise ratio and error counts to assist further.
07-02-2014 5:49 PM
07-02-2014 5:52 PM
07-02-2014 5:53 PM
Data Transferred (Sent/Received) [MB/GB]: 141.97 / 1.99
Output Power (Up/Down) [dBm]: 12.2 / 20.8
Line Attenuation (Up/Down) [dB]: 4.9 / 7.0
SN Margin (Up/Down) [dB]: 5.9 / 6.1
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Link (Remote): -
Error Seconds (Local/Remote): 13 / 0
FEC Errors (Up/Down): 837 / 22,222,806
CRC Errors (Up/Down): 1,275 / 13
HEC Errors (Up/Down): 975 / 88
07-02-2014 6:08 PM
Is your router connected into the master socket? Is there any noise on the line (dial 1700 option 2). Do you have a new filter you could try?
07-02-2014 6:10 PM
This is from my router
Uptime: 2 days, 5:29:58
Data Transferred (Sent/Received) [MB/GB]: 272,02 / 1,99
FEC Errors (Up/Down): 4.276 / 1.366.839
By comparison you have 16 times the number of FEC for less uptime and about half the usage
If Plusnet increase the default noise margin to 9dB it will slightly reduce the speed but hopefully will reduce the FEC count
In the meantime what is the noise margin late at night
07-02-2014 6:13 PM
