Usage Allowance being used up very quickly
- Usage Allowance being used up very quickly
Re: Usage Allowance being used up very quickly
06-11-2011 5:20 PM
06-11-2011 5:24 PM
06-11-2011 5:32 PM
06-11-2011 5:32 PM
06-11-2011 6:02 PM
Note 2.79MB in 2 minutes is equivalent to 2GB per day
06-11-2011 6:34 PM
06-11-2011 6:48 PM
06-11-2011 6:54 PM
Listening connections are those awaiting another system/application to connect to it.
You will often see a lot of things listening, this can be normal for the running of a network connected machine. The established will show for things like web-browsing as well.
Look under the established items and then at the Foreign Address column. The number after the colon will often help establish the application.
06-11-2011 6:59 PM
06-11-2011 7:00 PM
The last time I used the Free version of ZoneAlarm firewall, there was an option that could be selected where as each program attempted to access the internet a pop-up window appeared in which you had to ALLOW or DENY the connection.
If you did that, you would soon find out what was using the internet !
If you are running Linux, you could open "Firestarter", and just look at he "Active Connections", where it will list every connection made or active in the last few seconds.
06-11-2011 7:04 PM
06-11-2011 7:07 PM
06-11-2011 7:08 PM
06-11-2011 7:12 PM
06-11-2011 7:37 PM
