Usage Allowance being used up very quickly
- Usage Allowance being used up very quickly
Re: Usage Allowance being used up very quickly
06-11-2011 7:44 PM
This is really frustrating me, as you can tell I dont really understand it. We did not really want to go with plusnet but was our only option as sky did not have room on the exchange in our area. We were told 60gb was plenty for browsing, but obviously this isnt the case.
06-11-2011 7:53 PM
Quote We were told 60gb was plenty for browsing, but obviously this isnt the case.
60gb = 62914560 KB.
Average web page would be like, 30kb.
62914560 / 30 = 2097152 pages served.
60gb is MORE than enough for browsing.
You clearly have Some ONE or some THING using the internet without you realising.
Change your WEP/WPA key on your wireless, or better yet disable it for a day and just use the laptop via a cable. If the usage goes to a few MB, then you've found the problem.
I'd put money on either you have...
a) someone using your wireless (neighbour?)
b) some malware on your computer making it do 'things' over the internet
c) some software (torrent, iplayer, download etc.) is downloading and you do not realise this.
Also considering NetworX
Right click the icon, "USAGE STATS" -> then go to the "Hourly Rates" - gives you total transferred and also the average upload and download speed.
Jobs a good'un.
Regards
06-11-2011 7:55 PM
06-11-2011 9:09 PM
06-11-2011 9:14 PM
06-11-2011 9:16 PM
52MB is quite reasonable
06-11-2011 9:20 PM
52mb for 5 hours is low...
Mine looks like this...
See what i mean by hourly use (ignore the "constant" usage for several hours, its because my laptop was sat "on" and idle for several hours.
Green = Free period, Yellow = Offpeak, obvs.
The general page will also give you a 'days' overview.
Regards
06-11-2011 9:21 PM
06-11-2011 9:23 PM
06-11-2011 9:24 PM
06-11-2011 9:27 PM
1000 KB is 1 MB, 1000 MB is 1GB (sorry if this is obvious..)
100 meg is still nothing.
60 / 31 (for max amount of days) means you get 1.9gb per day to use. (averaged out)
So providing the next few days are "lower" than average until the end of the billing month, You should be fine.
Regards
P.S. What program is used to download torrents? i'd recommend uTorrent, as it includes a scheduler (which means it will NOT download during the daytime, even if the program is open in the background...)
edit: adding a picture
Like this -- White = stop totally, this means that you can leave the program and not worry about it wasting your allocated bandwidth.
06-11-2011 9:30 PM
06-11-2011 9:34 PM
06-11-2011 9:35 PM
https://www.plus.net/support/broadband/products/res_broadband_faq.shtml#overAllowance
Quote If you do hit the usage limit you've set your speed will be rate limited to 256kb/s until your next billing date. You can change this by increasing your maximum extra monthly spend or removing your Manage My Usage limit.
06-11-2011 9:37 PM
