BT Wholesale Broadband Performance Test FTTC
goldenfibre
Seasoned Pro
Fixes: 12
Re: BT Wholesale Broadband Performance Test FTTC
I had give up on BTw performance tester, As BT don't care and the worse ever. I think it's time for plusnet to add BT Exchange IP Profile & PN Current Line Speed on the member account instead. So, we don't have to use BTw speedtest anymore. So, we can use other speedtest.net instead but the problem is to get profile rate from exchange doesn't always work. Fed up with it with BT but I haven't use BTw because I know my speed is fine so far getting 74/19. And can see the BTO modem full sync rate 80/20.
Pettitto
Fixes: 5
Right,
Can I ask if anyone is having any further problems to provide some more screenshots please?
Can you ensure that they show/include the time/date in the bottom right hand corner?
This is for both TAP3 and the normal TAP Test.
AndyH
Screenshots attached.
The rest of the info I have posted before, but might be of use again.
PPP Connection from the test account:
ppp0       Link encap:Point-to-Point Protocol
          inet addr:172.16.73.176  P-t-P:81.146.179.4  Mask:255.255.255.255
          UP POINTOPOINT RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:3 errors:0 dropped:0 overruns:0 frame:0
          TX packets:76 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:3
          RX bytes:54 (54.0 B)  TX bytes:11228 (10.9 KiB)
Assigned DNS Servers (using the test account):
May 19 18:43:46 dnsmasq[1429]: using nameserver 194.72.9.34#53
May 19 18:43:46 dnsmasq[1429]: using nameserver 194.72.0.98#53
DNS Failures (unable to connect):
$ dig @194.72.9.34 speedtest.btwholesale.com
; <<>> DiG 9.8.3-P1 <<>> @194.72.9.34 speedtest.btwholesale.com
; (1 server found)
;; global options: +cmd
;; connection timed out; no servers could be reached
$ dig @194.72.0.98 speedtest.btwholesale.com
; <<>> DiG 9.8.3-P1 <<>> @194.72.0.98 speedtest.btwholesale.com
; (1 server found)
$ dig @194.72.0.98 test3.speedtest.btwholesale.com
; <<>> DiG 9.8.3-P1 <<>> @194.72.0.98 test3.speedtest.btwholesale.com
; (1 server found)
$ dig @194.72.9.34 test3.speedtest.btwholesale.com
; <<>> DiG 9.8.3-P1 <<>> @194.72.9.34 test3.speedtest.btwholesale.com
; (1 server found)
From my PN account (using the BT DNS servers - I can connect, but the lookup is refused):
; (1 server found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: REFUSED, id: 32857
;; flags: qr rd ra; QUERY: 0, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 0
;; Query time: 9 msec
;; SERVER: 194.72.0.98#53(194.72.0.98)
;; WHEN: Mon May 19 18:44:28 2014
;; MSG SIZE  rcvd: 12
; (1 server found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: REFUSED, id: 64882
;; Query time: 8 msec
;; SERVER: 194.72.9.34#53(194.72.9.34)
;; WHEN: Mon May 19 18:52:59 2014
From a BT Retail Connection (this is how it should respond - note that even though he could perform a DNS lookup, he could not connect to either http://speedtest.btwholesale.com or http://test3.speedtest.btwholesale.com):
root# nslookup speedtest.btwholesale.com 194.72.9.34
Server:    194.72.9.34
Address 1: 194.72.9.34 indnsc31.ukcore.bt.net
Address 1: 193.113.4.153
Address 2: 193.113.8.193
Address 3: 193.113.4.154
Address 4: 193.113.8.194
root# nslookup speedtest.btwholesale.com 194.72.0.98
Server:    194.72.0.98
Address 1: 194.72.0.98 indnsc60.ukcore.bt.net
Address 1: 193.113.4.154
Address 2: 193.113.8.194
Address 3: 193.113.4.153
Address 4: 193.113.8.193
Pettitto
Fixes: 5
Andy - you're a star!
goldenfibre
Seasoned Pro
Fixes: 12
Weirdo BT Speedtest (speed is faster than IP Profile)
Muttley62
petecov44
Hi Guys,
I am new to the service (yesterday) but I am also having problems. It just says " sending results to server" and flashes twice and then it says there was an error
goldenfibre
Seasoned Pro
Fixes: 12
BT Speedtest seem ok today but after sixth attempt trying
petecov44
I think i'll leave it a few weeks and see if it works then. I'm happy with the service too much to really care about it Smiley
Edit:: Thank you it's working now Smiley  Cheesy
Pettitto
Fixes: 5
We've got several teams with BT working on this at the moment. I met up with some of the chaps yesterday and I feel like we're making headway on the issue now.
I'll keep you posted but don't be alarmed if I don't have anything until the end of next week.
Pettitto
Fixes: 5
A fix went out last night which we're hoping may have fixed the issue.
Would anyone be able to test this for us at all?
goldenfibre
Seasoned Pro
Fixes: 12
1st test at 17:59 went ok (straight away show ip profile)
buseng12
Slightly O/T, but is the Tap3 test ever going to be fixed? Hasn't worked for months.
goldenfibre
Seasoned Pro
Fixes: 12
2nd test at 18:30 went ok (straight away show ip profile)
tijara33
Fixes: 6
I've just tried here, it looks fine to me. Smiley
