web browser
JamesM
web browser
I don't want to start a flame war here, but I have always used internet explorer (apart from Netscape many moons ago). The problem I am having is I have just gone to Win 8.1 and for some reason Battlelog (for BF4) needs a plug in, but the plug in will not work with IE 11 (security reasons). So I am thinking about another browser. Are there any pros and cons for say Chrome, FF or any other recommendations.
Thanks for reading.
10 REPLIES 10
rongtw
Fixes: 12
Re: web browser
James, i have always Used Firefox  Cool and never have problems with anything  Cool
Fixes: 1,484
Re: web browser
I switched to Chrome for a variety of reasons, but one being the bloat of firefox.
ReedRichards
Seasoned Pro
Fixes: 25
Re: web browser
Chrome will feed you adverts based on your past history of sites visited.  If you don't mind that or you install the Adblock extension then it's fine.
Fixes: 1,484
Re: web browser
Yup, use adblock and and ghostery...
JamesM
Re: web browser
I did a bit of reading, and read FF is the reincarnation of Netscape, so I gave it a try and BF4 is now working again.
Thanks for all your advice.
rongtw
Fixes: 12
Re: web browser
must admit i wasnt impressed when i tried Chrome Sad
SuperZoom
Re: web browser
Quote from: dvorak
On Windows, Pale Moon is an FF alternative, built from the same source code, which can help with that...
2u2me
Re: web browser
Switched from FF to Chrome a while back, no adverts with AaBlock installed, also remove all the flash from my PC`s as its aready in Chrome.
drj
Re: web browser
The major problem with Firefox - at least the way it's set up on my XP machine with the extensions I want - is it's a real memory hog! Starts at around 250K but left open will rise to over 1GB. On a machine with 2GB of RAM (expanded from the original 256K) that's an unacceptable amount of space being used up.
Mav
Fixes: 515
Re: web browser
On my 16GB RAM PC (Windows 7 Pro 64bit) it usually starts very low then gradually creeps up to a little over 2GB. I notice that web browsing starts to become sluggish at around around 1.5GB as well as Explorer also seems to be affected.
Quitting FF solves the issue till the next time Sad
Forum Moderator and Customer
