ring cameras on plus one hub
keithplusone
I have just installed my plusone hub and am having trouble installing my ring security cameras. I read somewhere that ring cameras may only work on 2.4 ghz and not 5 ghz. Has anyone installed these cameras on a plusone hub or use their hub only on 2.4ghz. How fast would it be on 2.4ghz?
6 REPLIES 6
Mook
Seasoned Champion
Fixes: 9
Re: ring cameras on plus one hub
Hello @keithplusone, Welcome to the Forum. It is only the Ring Pro that works on 5GHz, so what device do you have and what issues are you having while trying to install these?
As to how fast it? Well I can't answer as I have a Ring Pro and use the 5GHz band, but to be honest there is still lag when the doorbelll is active.
Edit: Typos
Fixes: 1,495
Moderators Note
This topic has been moved from ADSL Broadband to Tech Help.
keithplusone
thanks for your reply
Ihave a ring doorviewcam and a ring security cam solar but have only tried to reinstall the first item. Problem is that it will not talk to the hubone
Mook
Seasoned Champion
Fixes: 9
I'll assume the camera is fitted to the peephole, so when following these instructions, at what point is your issue?
Norrette
I have a doorbell and a battery cam hooked up to mine on 2.4GHz.  In fact that's the main reason I switched off 5GHZ as it seemed to interfere with the signal to these devices.   Speed isn't an issue with respect to the plusnet network, but it is an issue with the Ring servers.  I've never been able to view videos on my Samsung A5 phone, though the Samsung tablet is fine.
VileReynard
Fixes: 20
You might like a look at this 🙂
https://www.theguardian.com/technology/2020/mar/08/how-to-stop-your-smart-home-spying-on-you-lightbu...
