Youview update
petecov44
Re: Youview update
Quote from: AndyH
I can see the router issue coming up quite a bit - particularly if people are using their own routers. I assume Plusnet would have to put some disclaimer that it's only supported with certain routers provided by them.
Agreed. It was like that for a long time but when Ileft people were starting to support any d-link or netgear as it was all the same GUI.
TORPC
Re: Youview update
That is a thought
Will PN / Technicolor, upgrade the firmware to cater for the YouView boxes, like TalkTalk did ?Huh
Pettitto
Fixes: 5
Re: Youview update
The things you've mentioned have been taken into serious consideration.
TORPC
Re: Youview update
Cheers Chris
I thought as much tbh Smiley
The other alternative would be a different router altogether
Maybe another trial (if so) well, (hopefully) Wink Hint Hint
petecov44
Re: Youview update
Well even EE,  Beat you too it with their new service. You really DO drag your heals!
http://www.thinkbroadband.com/news/6659-ee-joins-the-tv-and-broadband-bundle-arena.html
Fixes: 1,483
Re: Youview update
errr no. it's basically a freeview dvr with the ability to stream to a device, there aren't any IPTV channels with that so not sure you can compare.
petecov44
Re: Youview update
okay well they got some sort of visual service out before these did.
Still shows how lame this "trial" is
Fixes: 1,483
Re: Youview update
no it doesn't, there's a difference between supplying a service and supplying a box.
petecov44
Re: Youview update
Well you have your opinion I'll have mine.
More money to EE for something PN cannot supply yet - that point you can not dispute!
Fixes: 1,483
Re: Youview update
EE aren't providing anything aside from a badged set top boxPN are attempting to deliver an IPTV service.
they are two totally dfferent things and afaik PN aren't trying to deliver just a set top box.
alanr74
Re: Youview update
Quote from: AndyH
. If it was me, I would hold fire and see what happens in the next couple of months.
Well Xmas is here and the turkey is getting fat!
Any news on this happening or is it as dead as a dodo.
godsell4
Re: Youview update
Ive given up on Youview, I was a trialist, and during the trial my box died, it was replaced and it too has died after 18 months, the quality of the Humax boxes is low.
3Mb FTTC
cajef
Re: Youview update
Not sure how you have had two boxes and the second one was supplied eighteen months ago when the start of the trial was only announced twelve months ago and then people had to apply to be on it.
dick:quote
Fixes: 1,483
Re: Youview update
godsell4 could have been referring to the original YouView trial not the PN trial.
godsell4
Re: Youview update
Err Yes, sorry. It was the original Youview trial I took part in.
3Mb FTTC
