Windows Explorer (or other progs) is not responding
- Windows Explorer (or other progs) is not respondin...
13-10-2010 8:42 AM
then I got a linky window to go to "fix the problem" on microsoft site... this came up with a story about the MFC file being corrupt and KB 972685 hot fix, should fix it... however this fix is dated July 2009, and I would have expected it to have been included in all the updates. downloaded automatically, since that date... (and since I installed a new HDD)...
when clicking on the "downloads" tab, I can find no place to actually down load KB972685, but two small .exe files underlined in blue....
do I just click on those two files? and will that "fix" the problem? (in other words are those two files, in fact, KB972685) ?? ?
Re: Windows Explorer (or other progs) is not responding
13-10-2010 9:43 AM
13-10-2010 10:06 AM
Yeah, that is the page I got to,,.... so have done the first file, and it has installed....
Finish page, says..... " it is highly recommended that you download and install the laterst service packs and security updates for this product........"
13-10-2010 10:09 AM
13-10-2010 10:19 AM
13-10-2010 10:33 AM
13-10-2010 3:21 PM
thanks very much...
13-10-2010 4:10 PM
Edit...Brain Malfunction...
13-10-2010 4:22 PM
your Secunia System Score of 100% is 5% HIGHER than the average user from England......
compared to users WITHOUT the Secunia PSI installed, your Secunia System Score is 10% HIGHER (more secure)
13-10-2010 4:46 PM
Quote Your secunia system score of 100% Is 5% Higher than the average user from Scotland....Compared to users without the secunia psi Installed your secunia score Is 15% Higher ( More secure )
Scotland Is......94.86%....( Close call )
13-10-2010 4:53 PM
13-10-2010 5:01 PM
