Why not a smartphone friendly website?
- Why not a smartphone friendly website?
12-07-2014 8:12 AM
I use my Galaxy a lot but the Plusnet portal and these fora are rubbish and I have to use a tablet or computer. C'mon Plusnet get up to date!
To be is to do - Kant
do be do be do - Sinatra
Re: Why not a smartphone friendly website?
13-07-2014 3:26 PM
been smartphone style doesnt mean up to date. many people still use pc's
every website I use that is phone friendly looks and feels like rubbish to use on a pc.
14-07-2014 2:04 PM
14-07-2014 3:04 PM
iplayer is now pretty bad after its touch screen optimisation update
skysports aweful
digitalspy aweful
its ok when the desktop layout is preserved and a seperate version is made for touch, but not ok when the main layout is changed for touch.
adie:quote
14-07-2014 3:18 PM
Quote from: PeterLoftus Simple question but probably a complicated answer
We're looking at it.
14-07-2014 3:21 PM
I then have to mess around finding where the 'desktop version' option is.
14-07-2014 4:02 PM
14-07-2014 5:33 PM
Thanks for that -What I expected but I was surprised no one else had asked such an obvious question!
By lurking on these forums I deduce that my experience is pretty typical. My family covers three generations and a number of different platforms. iPads, iPhones, laptops, PC et al and I usually am using what others allow me to. But I need to be able to check stuff and I note smartphone friendly is the new norm!
15-07-2014 11:21 AM
Quote from: Chris
request here to not change the layout, it works well now on modern pc's.
make a seperate website for mobile devices instead.
15-07-2014 6:59 PM
16-07-2014 9:29 AM
Quote from: RPMozley You don't need a separate site, it will be achieved by a mobile friendly forum skin (theme). This is usually just a more simplified layout, not any 'bangs & whistles' type of thing.
What you described is exactly what I dont want, its a myth that a site design can work well for both, designers think they do but they dont, simplification is exactyl what I dont want, sites look and feel aweful with it.
So either keep desktop focused or seperate in my view.
What you describe is what digitalspy did and its a disaster on there.
16-07-2014 5:15 PM
Just because one forum has done away with the desktop style altogether, does not mean every other will do the same by implementing a mobile friendly version.
So in other words, your opposition to this makes no sense, as I would think this desktop version will still remain.
16-07-2014 5:29 PM
16-07-2014 6:48 PM
not using full screen width, I have a wide screen monitor but its using a width suited to phones.
fonts too big, so have to do scrolling, could be shrunk then be better, but I guess was made big for phones
