New Java option to inhibit 'sponsor offers'
jelv
Fixes: 10
The latest version of Java has a new advanced option (see attached). Given the recent discussions we've had regarding toolbars no doubt we'll all be turning this on!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
6 REPLIES 6
avatastic
Re: New Java option to inhibit 'sponsor offers'
I read that, as it's Java, to mean "Hide the fact we're sneakily installing the ask.com toolbar. Again." rather than "Don't install the darn toolbar"
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
Strat
Fixes: 565
New Java Control Panel Option to Disable Sponsors
Prior to this release, to disable sponsor offers at the time of installation, the user can de-select the option during installation or can pass SPONSORS=0 as a commandline option. In this release, a new Java Control Panel (JCP) option to disable sponsors is available. To use this option, go to the JCP Advanced tab, and check or uncheck Suppress sponsor offers when updating Java. This option is applicable to 32- and 64-bit Windows operating systems.
Undecided
avatastic
I wonder if the box will automatically tick/untick itself after every update.
jelv
Fixes: 10
Strat beat me to posting that quote. It comes from http://java.com/en/download/java_update.jsp#techinfo
shutter
Fixes: 64
Just doing an "update" and the "normal" window with "install ASK toolbar"  is on my update.... just unchecked it... ( as normal ! )  Roll_eyes
Strat
Fixes: 565
I updated Java earlier and it broke my PC so I did a system restore.
