What is the max size of an email and what is the current size of the storage?
- Re: What is the max size of an email and what is t...
22-03-2012 5:43 AM
Re: What is the max size of an email and what is the current size of the storage?
22-03-2012 10:19 AM
Quote from: PlusComUK I'd also like to see a size per email column in the account summary.
You control this by the settings in the email client you are using.
22-03-2012 10:38 AM
22-03-2012 11:05 AM
Edit: and with RoundCube you can see the total usage for each folder.
22-03-2012 1:01 PM
I cannot see such an option.
22-03-2012 1:07 PM
22-03-2012 2:48 PM
22-03-2012 3:32 PM
Quote from: PlusComUK What is the max size of an email and what is the current maximum size of the storage?
The maximum size of an email is 100MB minus overheads:
bpullen>telnet relay.plus.net 25
220 avasout04 smtp relay.plus.net
ehlo avasout04
250-avasout04 hello [84.93.217.27], pleased to meet you
250-HELP
250-AUTH LOGIN PLAIN
250-SIZE 104857600 <--- This is the maximum allowed file size
250-PIPELINING
250-8BITMIME
250 OK
We ask that you keep the contents of your mailspace below 1GB.
Quote from: PlusComUK Why is there not a notification or graph of amount of storage used / available, as with other providers ?
Because customers' mailboxes do not have a hard quota configured on the server.
Quote from: PlusComUK Which my browser, Camino doesn't like !!
Why doesn't it like it? I've just send an email from Roundcube using Camino?
22-03-2012 3:38 PM
22-03-2012 3:49 PM
Quote from: Bob
Worth commenting that that is the limit after encoding. In practice it means a maximum attachment size of around 85MB.
23-03-2012 1:02 AM
Quote from: Bob We ask that you keep the contents of your mailspace below 1GB.
How can I keep track of how much data is in my "mailspace" so that I don't go over 1GB? Given that I have lots of folders on the server and use IMAP, the only way I can think of is to add up the sizes of every folder there. Isn't there an easier way?
23-03-2012 9:12 AM
26-03-2012 11:23 AM
Quote from: snozboz
The new Webmail platform will tell you folder size but only on a per folder basis. We provide plenty of warning before taking any measures against customers whose mailspace exceeds the limits in the AUP.
26-03-2012 11:29 AM
26-03-2012 7:26 PM
